Hi, I’m new to Linux, so I’m having a hard time installing CUDA and Nvidia drivers correctly.
I have an older graphic card at the moment, GeoForce GTX 260.
I had installed these drivers:
| NVIDIA-SMI 340.104 Driver Version: 340.104 |
| 0 GeForce GTX 260 Off | 0000:01:00.0 N/A | N/A |
| 40% 46C P12 N/A / N/A | 226MiB / 895MiB | N/A Default |
| Compute processes: GPU Memory |
| GPU PID Process name Usage |
I had CUDA installed but I was missing a file libcuda.so.1
So when trying to run Keras I was getting an import error:
libcuda.so.1
If I ran:
nvcc --version
Copyright (c) 2005-2016 NVIDIA Corporation
Built on Tue_Jan_10_13:22:03_CST_2017
Cuda compilation tools, release 8.0, V8.0.61
It would show CUDA is installed (I’m assuming).
So I asked here and reddit as to how to solve the missing file problem (I got no response here so I followed the directions on reddit, and I was told to install:
libcuda1-340
which I did.
But after restarting the computer, I’m getting a perpetual login loop.
Now If I run nvidia-bug-report from the tty1 console:
I get something like:
modprobe:libkmod/libkmod-module"c:832 kmod_module Error could not find module by name = ‘Nvidia_340’
modprobe: Error could not insert ‘nvidia-340’ Unknown Symbol
modprobe: Error could not find module by name = ‘Nvidia_340’
Complete:
