Persistent threads in OpenCL
Hi all,
I’m trying to make an ray-triangle accelerator on GPU and according to the article Understanding the Efficiency of Ray Traversal on GPUs one of the best solution is to make persistent threads. So, I launch just enough threads to fill the machine and each thread is getting it’s work from global “work queue”.
Code from the mentioned article (www.tml.tkk.fi/~timo/publications/aila2009hpg_paper.pdf)
// global variables
const int B = 3*32; // example batch size
const int globalPoolRayCount;
int globalPoolNextRay = 0;
__global__ void kernel()
// variables shared by entire warp, place to shared memory
  __shared__ volatile int nextRayArray[BLOCKDIM_Y];
  __shared__ volatile int rayCountArray[BLOCKDIM_Y] = f0g;
  volatile int& localPoolNextRay = nextRayArray[threadIdx.y];
  volatile int& localPoolRayCount = rayCountArray[threadIdx.y];
  while (true) f
    // get rays from global to local pool
    if (localPoolRayCount==0 && threadIdx.x==0) {
    localPoolNextRay = atomicAdd(globalPoolNextRay, B);
    localPoolRayCount = B; }
    // get rays from local pool
    int myRayIndex = localPoolNextRay + threadIdx.x;
    if (myRayIndex >= globalPoolRayCount)
      return;
    if (threadIdx.x==0) {
     localPoolNextRay += 32;
     localPoolRayCount -= 32;
   // init and execute, these must not exit the kernel
   fetchAndInitRay(myRayIndex);
   trace();
So I tried to port it to OpenCL, but I can’t get the desired result. What is wrong? Either I get CL_OUT_OF_RESOURCES or the generated image is wrong.
#pragma OPENCL EXTENSION cl_khr_global_int32_base_atomics : enable
#define B 3*32; // example batch size
// globalPoolNextRay is set to 0 in the cpp file
__kernel void kernel(__global int* globalPoolNextRay,  int globalPoolRayCount){
  __local volatile int localPoolNextRay;
  __local volatile int localPoolRayCount;
  if ( get_local_id(0) == 0){
    localPoolNextRay = localPoolRayCount = 0;
  mem_fence(CLK_LOCAL_MEM_FENCE);
  while(true){
    if ( localPoolRayCount == 0 && get_local_id(0) == 0){
      localPoolNextRay = atom_add(globalPoolNextRay,B);
    myRayIndex = localPoolNextRay + get_local_id(0);
    if ( myRayIndex > globalPoolRayCount)
      return;
    trace();
I’ll be glad for any suggestion as I’m at my wit’s end.
I finally figured it out! (mainly thanks to the AMD forum which is much more active than this one…) It is crucial to have block size to be equal to warp/wavefront size, so that the synchronization is explicit. I think, also updating the driver to 260.19.21 helped as well.
