Persistent warp and blend NVAPI
I would like to make the warp and blend persistent across reboot.
The following 2 APIs have a “sticky” output parameter indicating that this should be possible.
NvAPI_GPU_SetScanoutWarping
NvAPI_GPU_SetScanoutIntensity
However it is always returning 0, and I have not found a way to make it persist.
It would be great if someone could let me know which API should be used to toggle this.
Best,
Chi
Hi Chi,
Unfortunately we haven’t implemented a mechanism to make Warp and Blend persistent across reboots.
Our recommendation is to run the a utility defining the Warp and Blend at startup.
thanks,
Ian
