I’m running the DOCA eth_l2_fwd example like this:
./eth_l2_fwd/doca_eth_l2_fwd -d mlx5_0,mlx5_1
According to the manual, I’m using p0 and p1 normally. But now I’d like to use the PF representor, so traffic goes between something like:
[PF Representor] p0 <-> pf0hpf [PF]
I’m not sure how to make the app use the representor instead of the physical port.
Do I need to pass a different device name to -d, or is there some config needed on the driver or in DOCA to make the representor visible?
Basically, I want to send traffic between the PF and its representor using eth_l2_fwd, but I can’t figure out how to open that interface.
If anyone has an example, doc link, or code snippet that shows how to use representors with DOCA apps, I’d really appreciate it.
