pgc++ compiling error: union_find_last_lp_per_handler
Hi all,
I am using pgc++ to port some code previously compiled with g++. I received the following error:
$ pgc++ -fPIC   -I../../lib -I../../../nextgen/lib -DMAX_PATH=4096 -O2 -m64 -pthread     -MD -c abstract_iostream.cpp -o abstract_iostream.o
PGCC-S-0000-Internal compiler error. union_find_last_lp_per_handler:empty throw_bih       0 (/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../include/c++/4.1.2/iostream: 638)
PGCC/x86 Linux 13.5-0: compilation completed with severe errors
I created siterc to support the -pthread flag according to
http://www.pgroup.com/resources/openmpi/openmpi132_pgi90.htm
Any suggestion on the possible cause of this error is appreciated. Thank you.
Kevin
Hi Kevin,
This looks the same as a known compiler issue (TPR#19250) which will be fixed in the upcoming 13.6 release. The work around is to compile at “-O1” instead of “-O2”.
Best Regards,
Mat
Thank you. That fixes my problem.
kevin
