pgcc fails with GPU kernel containing switch statement
I have the following code that fails to work with the switch statement exceeds some threshold of cases. It works fine with a few cases, such as one or two, but when all 7 cases are given (and I in fact need more like 14 cases), the results are incorrect. You can see the faulty code here:
#include <math.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <inttypes.h>
#ifdef _OPENACC
#include <accelmath.h>
extern unsigned int __popcnt (unsigned int);
#endif
int isinit=0;
#define PI 3.14159265358979323846
typedef int32_t aplint32;typedef uint64_t BOUND;
typedef uint64_t B;typedef long long int L;typedef int32_t I;typedef double D;typedef void V;
typedef unsigned char U8;
struct array {I r; B s[15];I f;B c;B z;V*v;};
typedef struct array A;
#define DO(i,n) for(L i=0;i<(n);i++)
#define R return
V frea(A*a){if (a->v!=NULL){char*v=a->v;B z=a->z;
 if(a->f){
#ifdef _OPENACC
#pragma acc exit data delete(v[:z])
#endif
 if(a->f>1){free(v);}}}
V aa(A*a,I tp){frea(a);B c=1;DO(i,a->r)c*=a->s[i];B z=0;
 B pc=8*ceil(c/8.0);
 switch(tp){
  case 1:z=sizeof(I)*pc;break;
  case 2:z=sizeof(D)*pc;break;
  case 3:z=ceil((sizeof(U8)*pc)/8.0);break;
  default: error(16);}
 z=4*ceil(z/4.0);char*v=malloc(z);if(NULL==v)error(1);
 #ifdef _OPENACC
  #pragma acc enter data create(v[:z])
 #endif
 a->v=v;a->z=z;a->c=c;a->f=2;}
V ai(A*a,I r,B *s,I tp){a->r=r;DO(i,r)a->s[i]=s[i];aa(a,tp);}
V fe(A*e,I c){DO(i,c){frea(&e[i]);}}
V cpaa(A*t,A*s){frea(t);memcpy(t,s,sizeof(A));}
#ifdef _OPENACC
#pragma acc routine seq
#endif
D gcd(D an,D bn){D a=fabs(an);D b=fabs(bn);
 for(;b>1e-10;){D n=fmod(a,b);a=b;b=n;};R a;}
#ifdef _OPENACC
#endif
D lcm(D a,D b){D n=a*b;D z=fabs(n)/gcd(a,b);
 if(a==0&&b==0)R 0;if(n<0)R -1*z;R z;}
#ifdef _OPENACC
#endif
D circ(I a,D b){switch(a){
  case 0:return sqrt(1-b*b);break;
  case 1:return sin(b);break;
  case 2:return cos(b);break;
  case 3:return tan(b);break;
  case 4:return sqrt(1+b*b);break;
  case 5:return sinh(b);break;
  case 6:return cosh(b);break;
  case 7:return tanh(b);break;
 };return -1;}
A*tenv=NULL;
A*env[]={NULL};
static void fn_1_1fi(A*z,A*l,A*r,A*penv[]){
A env0[1];A*env[]={env0,penv[0]};
DO(i,1)env0[i].v=NULL;
{I prk=0;B sp[15];B cnt=1;
if(prk!=(l)->r){if(prk==0){
prk=(l)->r;
DO(i,prk) sp[i]=(l)->s[i];}else if((l)->r!=0)error(4);
}else{
DO(i,prk){if(sp[i]!=(l)->s[i])error(4);}}
if(prk!=(r)->r){if(prk==0){
prk=(r)->r;
DO(i,prk) sp[i]=(r)->s[i];}else if((r)->r!=0)error(4);
}else{
DO(i,prk){if(sp[i]!=(r)->s[i])error(4);}}
DO(i,prk)cnt*=sp[i];A p0;p0.v=NULL;
ai(&p0,prk,sp,2);
double *restrict r0=p0.v;
aplint32 *restrict d0=(l)->v;
I m0=(l)->r==0?0:1;
double *restrict d1=(r)->v;
I m1=(r)->r==0?0:1;
I n=ceil(cnt/8.0);
#pragma acc kernels loop independent present(d0,d1) present(r0)
DO(i,n){
aplint32 f0_0=d0[(i*8+0)*m0];
aplint32 f0_1=d0[(i*8+1)*m0];
aplint32 f0_2=d0[(i*8+2)*m0];
aplint32 f0_3=d0[(i*8+3)*m0];
aplint32 f0_4=d0[(i*8+4)*m0];
aplint32 f0_5=d0[(i*8+5)*m0];
aplint32 f0_6=d0[(i*8+6)*m0];
aplint32 f0_7=d0[(i*8+7)*m0];
double f1_0=d1[(i*8+0)*m1];
double f1_1=d1[(i*8+1)*m1];
double f1_2=d1[(i*8+2)*m1];
double f1_3=d1[(i*8+3)*m1];
double f1_4=d1[(i*8+4)*m1];
double f1_5=d1[(i*8+5)*m1];
double f1_6=d1[(i*8+6)*m1];
double f1_7=d1[(i*8+7)*m1];
double s0_0=circ(f0_0,f1_0);
double s0_1=circ(f0_1,f1_1);
double s0_2=circ(f0_2,f1_2);
double s0_3=circ(f0_3,f1_3);
double s0_4=circ(f0_4,f1_4);
double s0_5=circ(f0_5,f1_5);
double s0_6=circ(f0_6,f1_6);
double s0_7=circ(f0_7,f1_7);
r0[i*8+0]=s0_0;
r0[i*8+1]=s0_1;
r0[i*8+2]=s0_2;
r0[i*8+3]=s0_3;
r0[i*8+4]=s0_4;
r0[i*8+5]=s0_5;
r0[i*8+6]=s0_6;
r0[i*8+7]=s0_7;
cpaa(&env[0][0],&p0);
cpaa(z,&env[0][0]);
fe(&env0[1],0);}
int main(int argc,char *argv[]){A lft,rgt,rslt;lft.v=NULL;rgt.v=NULL;rslt.v=NULL;
 I lr,rr;B ls[15];B rs[15];lr=0;rr=1;rs[0]=10;ai(&lft,lr,ls,1);ai(&rgt,rr,rs,2);
 I*restrict lv;D*restrict rv;lv=lft.v;rv=rgt.v;lv[0]=0;
 D fill[]={0.9699840091,0.3438302648,0.3072080448,0.88552625,0.9481495967,
  0.2846852611,0.4784076374,0.9853858535,0.05687102809,0.6987214631};
 DO(i,10){rv[i]=fill[i];}
 DO(i,10)printf("%f ",rv[i]);printf("\n");
#pragma acc update device(lv[:1],rv[:10])
 fn_1_1fi(&rslt,&lft,&rgt,env);
 D*restrict zv=rslt.v;
#pragma acc update host(zv[:10])
 DO(i,10)printf("%f ",zv[i]);printf("\n");
 return 0;}
The code should produce the following values:
0.969984 0.343830 0.307208 0.885526 0.948150 0.284685 0.478408 0.985386 0.056871 0.698721
0.243169 0.939032 0.951642 0.464589 0.317824 0.958621 0.878138 0.170337 0.998382 0.715394
But instead I get something like this when there are many cases in the circ() function:
0.824877 0.337096 0.302399 0.774248 0.812338 0.280855 0.460366 0.833485 0.056840 0.643239
Could someone explain why this is? Is there some way to fix this?
Hi Aaron,
Looks like another bug. I wrote up a report (TPR#22345) and sent it off to engineering so it can be fixed.
The problem looks to only occur when using a case label with “0”. So as a work around, add 1 to the expression and each case label. Alternately, you can use if statements.
#ifdef WORKS
switch(a+1){
   case 1:return sqrt(1-b*b);break;
   case 2:return sin(b);break;
   case 3:return cos(b);break;
   case 4:return tan(b);break;
   case 5:return sqrt(1+b*b);break;
   case 6:return sinh(b);break;
   case 7:return cosh(b);break;
   case 8:return tanh(b);break;
#else
switch(a){
#endif
% pgcc -V16.1 test_030816.c -fast -acc -DWORKS ; a.out
% pgcc -V16.1 test_030816.c -fast -acc  ; a.out
Thanks for the report!
Mat
I appreciate the information and the workaround appears to be working, though I would appreciate some sort of notification when this is fixed in a future version so that I can remove this workaround on my end.
Hi Aaron,
I added a note asking PGI Customer support to contact you once the fix is available in a release. I used the email you have associated with your PGI web user account.
  • Mat
