pgcc Preprocessor Error: Documentation?!
I’m getting a “Syntax error in #if directive” error message for some C code I’m trying to port to Linux pgcc. I cannot seem to find any documentation for the preprocessor other than command-line options?!
The code in question is:
#if VERSION==DLL
where VERSION and DLL are both #defined previously in the file.
This works fine in gcc 4.1.1 as well as Visual Studio.
Any hints to what the “syntax error” is, or a pointer to PGI’s preprocessor documentation?
Thanks,
Matt
Hi Matt,
It’s most likely a problem with the values being used fo VERSION and DLL. What are these being defined to?
  • Mat
Yup. Someone was mixing C/C++ style comments thus leading to bizarre syntax issues. Using ‘-B’ fixed it right up.
Thanks,
Matt
