I am trying to compile some code using PGI OpenAcc and I want to run the parallel loop of Tesla. I am getting the following errors. Any help is highly appreciated?
Thanks,
OS: RED HAT Enterprise Workstation
OpenACC Toolkit 2015
compilation command line:
pgc++ -I/usr/local/include/ -I/opt/Shark/include/ -acc -DNDEBUG -DBOOST_UBLAS_NDEBUG -O3 -L/home/jooya/Shark/lib -lshark -lboost_serialization -lboost_system -lboost_filesystem -lboost_program_options NN_Shark.cpp -c
Errors:
PGCC-S-0094-Illegal type conversion required (/opt/Shark/include/shark/ObjectiveFunctions/AbstractConstraintHandler.h: 74)
PGCC-S-0000-Internal compiler error. BAD sptr in var_refsym 0 (/opt/Shark/include/shark/ObjectiveFunctions/AbstractConstraintHandler.h: 74)
PGCC-S-0000-Internal compiler error. BAD sptr in func_refsym 0 (/opt/Shark/include/shark/ObjectiveFunctions/AbstractConstraintHandler.h: 74)
PGCC-S-0000-Internal compiler error. BAD sptr in var_refsym 0 (/opt/Shark/include/shark/Core/Flags.h: 137)
PGCC/x86 Linux 15.7-0: compilation completed with severe errors
make: *** [NN_Shark.o] Error 2
Here is AbstractConstraintHandler.h:
* \brief Base class for constraints.
* \author O.Krause
* \date 2013
* \par Copyright 1995-2015 Shark Development Team
* <BR><HR>
* This file is part of Shark.
* <http://image.diku.dk/shark/>
* Shark is free software: you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published
* by the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* Shark is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU Lesser General Public License for more details.
* You should have received a copy of the GNU Lesser General Public License
* along with Shark. If not, see <http://www.gnu.org/licenses/>.
#ifndef SHARK_OBJECTIVEFUNCTIONS_ABSTRACTCONSTRAINTHANDLER_H
#define SHARK_OBJECTIVEFUNCTIONS_ABSTRACTCONSTRAINTHANDLER_H
#include <shark/Core/Exception.h>
#include <shark/Core/Flags.h>
namespace shark{
/// \brief Implements the base class for constraint handling.
/// A constraint handler provides information about the feasible region of a constrained optimization problem.
/// In the minimum it checks whether a point is feasible, or what the next fasible point would be.
template<class SearchPointType>
class AbstractConstraintHandler{
public:
enum Feature {
CAN_PROVIDE_CLOSEST_FEASIBLE = 1, ///< The constraint handler can provide a close feasible point to an infeasible one
IS_BOX_CONSTRAINED = 2, ///< The constraint handler is an instance of BoxConstraintHandler
CAN_GENERATE_RANDOM_POINT = 4 ///< The ConstraintHandler can generate a random point inside the feasible region
SHARK_FEATURE_INTERFACE;
virtual ~AbstractConstraintHandler(){}
/// \brief Returns whether this function can calculate the closest feasible to an infeasible point.
bool canProvideClosestFeasible()const{
return m_features & CAN_PROVIDE_CLOSEST_FEASIBLE;
/// \brief Returns whether this function is an instance of BoxConstraintHandler
bool isBoxConstrained()const{
return m_features &IS_BOX_CONSTRAINED;
bool canGenerateRandomPoint()const{
return m_features & CAN_GENERATE_RANDOM_POINT;
/// \brief If supported, generates a random point inside the feasible region.
virtual void generateRandomPoint( SearchPointType & startingPoint )const {
SHARK_FEATURE_EXCEPTION(CAN_GENERATE_RANDOM_POINT);
/// \brief Returns true if the point is in the feasible Region.
/// This function must be implemented by a ConstraintHandler
virtual bool isFeasible(SearchPointType const&)const = 0;
virtual void closestFeasible(SearchPointType& )const{
SHARK_FEATURE_EXCEPTION(CAN_PROVIDE_CLOSEST_FEASIBLE );
#endif
and Flags.h:
* \brief Flexible and extensible mechanisms for holding flags.
* \author T.Voss
* \date 2010-2011
* <BR><HR>
#ifndef SHARK_CORE_FLAGS_H
#define SHARK_CORE_FLAGS_H
#include <shark/Core/ISerializable.h>
namespace shark {
/// \brief Flexible and extensible mechanisms for holding flags.
/// \par
/// The world's most airbrushed integer ever...
/// \par
/// This class encapsulates a flexible mechanism for holding flags.
/// Its templatization makes it possible to base it on any base
/// type, while unsigned int will be the most common choice. This
/// mechanism makes it possible, in principle, to support as many
/// flags as needed. Furthermore, classes may extend the flags
/// defined by their superclass.
template<typename Flag>
class TypedFlags : public ISerializable {
public:
TypedFlags() : m_flags( 0 ) { }
TypedFlags(TypedFlags const& other) : m_flags(other.m_flags) { }
virtual ~TypedFlags() {}
inline TypedFlags<Flag> & operator = ( TypedFlags<Flag> const& rhs ) {
m_flags = rhs.m_flags;
return( *this );
inline void set( Flag f ) {
m_flags |= f;
inline void setAll() {
m_flags |= ~0;
inline void reset() {
m_flags = 0;
inline void reset( Flag f ) {
m_flags &= ~f;
inline bool test( Flag f ) const {
return ( m_flags & f) == (unsigned int)f;
inline bool operator&( Flag f ) const {
inline TypedFlags<Flag> & operator|=( Flag f ) {
m_flags |= f;
return( *this );
inline TypedFlags<Flag> & operator|=(const TypedFlags<Flag>& flags ) {
m_flags |= flags.m_flags;
return( *this );
inline TypedFlags<Flag> operator|( Flag f ) const {
TypedFlags<Flag> copy( *this );
copy |= f;
return( copy );
inline TypedFlags<Flag> operator|(const TypedFlags<Flag>& flags ) const {
copy |= flags;
return copy;
virtual void read( InArchive & archive )
{ archive & m_flags; }
virtual void write( OutArchive & archive ) const
protected:
unsigned int m_flags;
/// \brief Exception indicating the attempt to use a feature which is not supported
template<class Feature>
class TypedFeatureNotAvailableException : public Exception {
public:
TypedFeatureNotAvailableException( Feature feature, const std::string & file = std::string(), unsigned int line = 0 )
: Exception( "Feature not available", file, line ),
m_feature( feature ) {}
TypedFeatureNotAvailableException( const std::string & message, Feature feature, const std::string & file = std::string(), unsigned int line = 0 )
: Exception( message, file, line ),
Feature feature() const {
return m_feature ;
protected:
Feature m_feature;
namespace boost {
namespace serialization {
template< typename T >
struct tracking_level< shark::TypedFlags<T> > {
typedef mpl::integral_c_tag tag;
BOOST_STATIC_CONSTANT( int, value = track_always );
#define SHARK_FEATURE_INTERFACE \
typedef TypedFlags<Feature> Features;\
protected:\
Features m_features;\
public:\
const Features & features() const {\
return( m_features );\
virtual void updateFeatures(){}\
typedef TypedFeatureNotAvailableException<Feature> FeatureNotAvailableException
/// Throws an Exception when called.
/// This macro should be used in default implementations of the interface.
/// This define also checks first whether the feature is set to true inside the class.
/// If this is the case then we have encountered a programming mistake - so we assert instead.
#define SHARK_FEATURE_EXCEPTION(FEATURE) \
{assert(!(this->features()&FEATURE));\
throw FeatureNotAvailableException("Class does not support Feature " #FEATURE, FEATURE,__FILE__, __LINE__);}
/// Same as SHARK_FEATURE_EXCEPTION, but used when called from a derived class.
/// Assumes that a typedef "base_type" for the Baseclass exists
#define SHARK_FEATURE_EXCEPTION_DERIVED(FEATURE) \
{assert(!(this->features()&base_type::FEATURE));\
throw typename base_type::FeatureNotAvailableException("Class does not support Feature " #FEATURE, base_type::FEATURE,__FILE__, __LINE__);}
/// Checks whether the feature is available, if not, it throws an exception.
#define SHARK_FEATURE_CHECK(FEATURE)\
if(!(this->features()&base_type::FEATURE)){SHARK_FEATURE_EXCEPTION_DERIVED(FEATURE);}
#endif // SHARK_CORE_FLAGS_H
