I have a code: GitHub - AndStorm/openacc: GPU OPENACC PROBLEM.
I can not compile it to launch on GPU using OpenAcc and PGI 19.4 C++ compiler pgc++,
CUDA 10.1 installed properly and the Nvidia driver version 418.67, cmake 3.13.1.
The GPU on my machine is GeForce GTX 650 Ti. The OS is Fedora 23 x86_64.
- The compilation fails with an error (ERRGPU.txt in the repository):
PGCC-S-1000-Call in OpenACC region to procedure 'memmove' which has no acc routine information (/home/70-gaa/NFbuild_script_CHECK_GPU/source/nbody.cpp: 93)
PGCC-W-0155-Compiler failed to translate accelerator region (see -Minfo messages): Missing branch target block (/home/70-gaa/NFbuild_script_CHECK_GPU/source/nbody.cpp: 1)
PGCC-F-0704-Compilation aborted due to previous errors. (/home/70-gaa/NFbuild_script_CHECK_GPU/source/nbody.cpp)
PGCC/x86-64 Linux 19.4-0: compilation aborted
I use the following compile line:
cmake . -DCMAKE_C_COMPILER=pgcc -DCMAKE_CXX_COMPILER=pgc++ -DCMAKE_CXX_FLAGS="-acc -mcmodel=medium -ta=tesla:cc30,nollvm,managed -fast -Mcuda=cuda10.1" -DCMAKE_CXX_STANDARD=17 ("managed" - try to yse CUDA unified memory).
DCMAKE_CXX_STANDARD=17 is necesary for compilation of T3ParticleTable.cpp and T3MaterialTable.cpp.
and i make necessary for using cudaMemcpy() #include’s in the beginning of T3DataHolder.h - lines 38-43:
#ifdef OPENACC
#include <accelmath.h>
#include <openacc.h>
#include <cuda.h>
#include <cuda_runtime.h>
#endif
What causes this error? And how to avoid it?
- In nbody.cpp, where there is main(), i try to allocate DataHolder on GPU as:
DataHolder<FloatingType> * data;
cudaMalloc((void**) & data, sizeof(DataHolder<FloatingType>));
cudaFree(data);
Is it right? Or maybe use #pragma acc data create(d) clause in main:
DataHolder<FloatingType> d;
and copy the object to GPU?
3) If to comment //#define OPENACC at line 13 of T3Defs.h (use OpenMP #pragma’s and execute code on CPU),
the code compiles and works well on CPU with the compile line:
cmake . -DCMAKE_C_COMPILER=pgcc -DCMAKE_CXX_COMPILER=pgc++ -DCMAKE_CXX_FLAGS="-acc -ta=multicore -fast" -DCMAKE_CXX_STANDARD=17.
But if to uncomment
Floating csBorder[numi+1];
at line 48 of T3MultipleScatteringFSImpl.h and comment the 2 following lines:
std::vector<Floating> csBorder;
csBorder.resize(numi+1);
the compilation fails with the following error (ERRCPU.txt in repository):
line 173: internal error: assertion failed at: "../src/statements.c"
1 error and 1 catastrophic error detected in the compilation of "/home/70-gaa/NFbuild_script_CHECK_GPU/source/nbody.cpp".
Compilation aborted.
Why?
I have already been working on solving these problems for several days, but do not know what to do. Please, help me.
