I compile the following example code using both pgcc 11.4 and 12.3:
#include <stdio>
#include <float>
int main ()
printf("DBL_MIN = %e\n", DBL_MIN);
printf("DBL_MAX = %e\n", DBL_MAX);
return 0;
pgcc Version 11.4 is successful:
machine 531: pgcc -V -o dbl_max_test.x dbl_max_test.c
pgcc 11.4-0 64-bit target on x86-64 Linux -tp istanbul
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2011, STMicroelectronics, Inc. All Rights Reserved.
PGC/x86-64 Linux 11.4-0
godzilla.lanl.gov 532: pgcc -V -v -o dbl_max_test.x dbl_max_test.c
/opt/local/vendor/pgi-11.4/linux86-64/11.4/bin/pgc dbl_max_test.c -opt 1 -version -x 119 0xa10000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 127 17 -x 19 0x400000 -x 28 0x40000 -x 120 0x10000000 -x 70 0x8000 -x 122 1 -x 125 0x20000 -quad -x 59 4 -x 59 4 -tp istanbul -x 120 0x1000 -astype 0 -stdinc /opt/local/vendor/pgi-11.4/linux86-64/11.4/include-gcc41:/opt/local/vendor/pgi-11.4/linux86-64/11.4/include:/usr/local/include:/usr/lib/gcc/x86_64-redhat-linux/4.1.2/include:/usr/lib/gcc/x86_64-redhat-linux/4.1.2/include:/usr/include -def unix -def __unix -def __unix__ -def linux -def __linux -def __linux__ -def __NO_MATH_INLINES -def __x86_64__ -def __LONG_MAX__=9223372036854775807L -def '__SIZE_TYPE__=unsigned long int' -def '__PTRDIFF_TYPE__=long int' -def __THROW= -def __extension__= -def __amd64__ -def __SSE__ -def __MMX__ -def __SSE2__ -def __SSE3__ -def __SSE4A__ -def __ABM__ -predicate '#machine(x86_64) #lint(off) #system(posix) #cpu(x86_64)' -cmdline '+pgcc dbl_max_test.c -V -v -o dbl_max_test.x' -x 123 0x80000000 -x 123 4 -x 2 0x400 -x 119 0x20 -def __pgnu_vsn=40102 -alwaysinline /opt/local/vendor/pgi-11.4/linux86-64/11.4/lib/libintrinsics.il 4 -x 120 0x200000 -asm /tmp/pgccVfLenHYQPQlN.s
PGC-I-0222-Redundant definition for symbol __THROW (/usr/include/sys/cdefs.h: 63)
PGC-I-0222-Redundant definition for symbol __extension__ (/usr/include/sys/cdefs.h: 287)
PGC/x86-64 Linux 11.4-0: compilation completed with informational messages
/usr/bin/as /tmp/pgccVfLenHYQPQlN.s -o /tmp/pgccNfLe1QM0hcO-.o
/usr/bin/ld /usr/lib64/crt1.o /usr/lib64/crti.o /opt/local/vendor/pgi-11.4/linux86-64/11.4/lib/trace_init.o /usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtbegin.o /opt/local/vendor/pgi-11.4/linux86-64/11.4/lib/initmp.o -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 /opt/local/vendor/pgi-11.4/linux86-64/11.4/lib/pgi.ld -L/opt/local/vendor/pgi-11.4/share_objects/lib64 -L/opt/local/vendor/pgi-11.4/linux86-64/11.4/lib -L/usr/lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2 /tmp/pgccNfLe1QM0hcO-.o -rpath /opt/local/vendor/pgi-11.4/share_objects/lib64 -rpath /opt/local/vendor/pgi-11.4/linux86-64/11.4/lib -o dbl_max_test.x /opt/local/vendor/pgi-11.4/linux86-64/11.4/lib/nonuma.o -lpgmp -lpthread -lnspgc -lpgc -lm -lgcc -lc -lgcc /usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtend.o /usr/lib64/crtn.o
Unlinking /tmp/pgccVfLenHYQPQlN.s
Unlinking /tmp/pgccNfLe1QM0hcO-.o
godzilla.lanl.gov 533: db
db2dvi db41_dump db42_checkpoint db42_verify db_printlog dbilogstrip dbus-launch
db2html db41_load db42_deadlock db_archive db_recover dbimp dbus-monitor
db2pdf db41_printlog db42_dump db_checkpoint db_stat dbiprof dbus-send
db2ps db41_recover db42_load db_codegen db_upgrade dbiproxy dbus-uuidgen
db2rtf db41_stat db42_printlog db_deadlock db_verify dbl_max_test.x
db41_archive db41_upgrade db42_recover db_dump dbconverter-2 dbus-binding-tool
db41_checkpoint db41_verify db42_stat db_hotbackup dbcp dbus-cleanup-sockets
db41_deadlock db42_archive db42_upgrade db_load dbdump dbus-daemon
pgcc Version 12.3 fails:
machine 539: pgcc -V -v -o dbl_max_test.x dbl_max_test.c
pgcc 12.3-0 64-bit target on x86-64 Linux -tp istanbul
Copyright 2000-2012, STMicroelectronics, Inc. All Rights Reserved.
/opt/local/vendor/pgi-12.3/linux86-64/12.3/bin/pgc dbl_max_test.c -opt 1 -version -x 119 0xa10000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 127 17 -x 19 0x400000 -x 28 0x40000 -x 120 0x10000000 -x 70 0x8000 -x 122 1 -x 125 0x20000 -quad -x 59 4 -x 59 4 -tp istanbul -x 120 0x1000 -astype 0 -stdinc /opt/local/vendor/pgi-12.3/linux86-64/12.3/include:/usr/local/include:/usr/lib/gcc/x86_64-redhat-linux/4.1.2/include:/usr/lib/gcc/x86_64-redhat-linux/4.1.2/include:/usr/include -def unix -def __unix -def __unix__ -def linux -def __linux -def __linux__ -def __NO_MATH_INLINES -def __x86_64__ -def __LONG_MAX__=9223372036854775807L -def '__SIZE_TYPE__=unsigned long int' -def '__PTRDIFF_TYPE__=long int' -def __THROW= -def __extension__= -def __amd64__ -def __SSE__ -def __MMX__ -def __SSE2__ -def __SSE3__ -def __SSE4A__ -def __ABM__ -predicate '#machine(x86_64) #lint(off) #system(posix) #cpu(x86_64)' -cmdline '+pgcc dbl_max_test.c -V -v -o dbl_max_test.x' -x 123 0x80000000 -x 123 4 -x 2 0x400 -x 119 0x20 -def __pgnu_vsn=40102 -alwaysinline /opt/local/vendor/pgi-12.3/linux86-64/12.3/lib/libintrinsics.il 4 -x 120 0x200000 -asm /tmp/pgccOHoh44xSBGj7.s
PGC/x86-64 Linux 12.3-0
PGC-S-0039-Use of undeclared variable __DBL_MIN__ (dbl_max_test.c: 6)
PGC-S-0039-Use of undeclared variable __DBL_MAX__ (dbl_max_test.c: 7)
PGC/x86-64 Linux 12.3-0: compilation completed with severe errors
pgcc-Fatal-ccompile completed with exit code 1
Unlinking /tmp/pgccOHoh44xSBGj7.s
The float.h is found for pgcc 11.4 as follows::
machine 541: find /opt/local/vendor/pgi-11.4/linux86-64/11.4 -name float.h
/opt/local/vendor/pgi-11.4/linux86-64/11.4/include/float.h
The float.h is found for pgcc 12.3 as follows::
machine 542: find /opt/local/vendor/pgi-12.3/linux86-64/12.3 -name float.h
/opt/local/vendor/pgi-12.3/linux86-64/12.3/include-gcc41/float.h
/opt/local/vendor/pgi-12.3/linux86-64/12.3/include-gcc40/float.h
/opt/local/vendor/pgi-12.3/linux86-64/12.3/include-gcc34/float.h
/opt/local/vendor/pgi-12.3/linux86-64/12.3/include-gcc33/float.h
I do not know if this is a problem with our installation of 12.3 or is a bug. Any help is appreciated.[/code]
