hello I’m all new to parallel programming and got a job like this. My task is to parallel this algorithm. I’ve tried a couple of different ways on your forum, but it doesn’t work.
Could someone see this particular case and suggest what needs to be done to get it to run properly.
The program consists of three files, I will post Below I will put the algorithm code,
acc_init(acc_device_nvidia);
begin = omp_get_wtime();
RasterizedPolygon *rasterizedPolygons = new RasterizedPolygon[pcount];
int start_row = 0;
int end_row = tiff_height;
int idBlock = 0;
polygon *one_polygon;
ring *one_ring;
#pragma acc data copy(rasterizedPolygons[0:pcount])\
copyin(pBlocks[0:blocksCount],adfGeoTransform)
#pragma acc parallel loop private ( start_row, end_row,idBlock)
for ( int linex=start_row; linex < end_row; linex++ )
double dy = adfGeoTransform[3] + 0 * adfGeoTransform[4] + (linex+0.5) *
adfGeoTransform[5];
// sprawdzenie w ktorym bolku miesci sie linia
#pragma acc loop private(block)
int block;
for ( block=0; block<blocksCount; block++)
if (dy >= pBlocks[block].min && dy < pBlocks[block].max)
idBlock = block;
break;
// szukanie poligonow tylko w tym bloku
for (int polyId=0; polyId < pBlocks[idBlock].indexes.size(); polyId++)
int polygony = pBlocks[idBlock].indexes[polyId];
one_polygon = polygons+polygony;
int rcount = one_polygon->rings.size();
for (int nring=0; nring <rcount; nring++)
one_ring = one_polygon->rings[nring];
int vcount = one_ring->points.size();
for ( int vertexz=0; vertexz < vcount-1; vertexz++)
double dx1, dy1, dx2, dy2;
// d1 < d2
dx1 = one_ring->points[vertexz]->x;
dx2 = one_ring->points[vertexz+1]->x;
dy1 = one_ring->points[vertexz]->y;
dy2 = one_ring->points[vertexz+1]->y;
if (dy1 > dy2)
int pom1 = dx1;
dx1=dx2;
dx2=pom1;
int pom2=dy1;
dy1=dy2;
dy2=pom2;
// myswap(dx1, dx2);
//myswap(dy1, dy2);
if ((dy < dy2)&&(dy>=dy1))
// obliczanie wspolrzednej przeciecia
double ionx = (dy-dy1)*(dx2-dx1)/(dy2-dy1)+dx1;
// nr kolumny w pixelach
int x = (ionx - adfGeoTransform[0] -
linex * adfGeoTransform[2] ) /
adfGeoTransform[1];
rasterizedPolygons[polygony].
addIntersect(linex, x);
The compiler displays errors:
rasterize(std::basic_string<char, std::char_traits, std::allocator>, std::basic_string<char, std::char_traits, std::allocator>, int, int, int):
196, Generating copy(rasterizedPolygons[:pcount])
Generating copyin(pBlocks[:blocksCount],adfGeoTransform[:])
Accelerator kernel generated
Generating Tesla code
200, #pragma acc loop gang /* blockIdx.x /
210, #pragma acc loop seq
219, #pragma acc loop seq
225, #pragma acc loop seq
230, #pragma acc loop vector(128) / threadIdx.x */
225, Loop is parallelizable
230, Loop is parallelizable
PGCC-W-0155-External and Static variables are not supported in acc routine - _ZN46_INTERNAL_24_librasterizationACC2_cpp_ce5c3146St19piecewise_constructE (librasterizationACC2.cpp: 465)
librasterizationACC2.cpp (12.1 KB) librasterizationACC2.h (1.4 KB) mainACC2.cpp (566 Bytes)
