When I compile our programme with pgf90 -Mmpi it gives the following error message and doesn’t produce an exe file. We use Windows Server 2008 R2 and MS MPI. Could anybody help?
C:\PROGRA~1\PGI/win64/11.7/bin\pgcnv.EXE C:\temp\pgf906eQCyd_z6mMCag.obj C:\temp
\pgf907f6CydUPnXRShV.obj
C:\PROGRA~1\PGI/win64/11.7/bin\pgcnv.EXE: fread: cannot read data
pgf90-Fatal-conv completed with exit code 1
The error seems to indicate that pgcnv can’t read the temporary object files. Does the directory “C:\temp” exist and do you have permissions to read/write to it?
Try setting the environment variable “TMP” to a directory that you know you have read/write permissions.
We’ve got other applications compiling and working without MPI. This one gives just linker errors without -Mmpi.
The output I posted comes from -v option. These are the last lines and there are thousands of lines before that. I could email you the rest if you send me your email address.
