I’ve been attempting to get pgcollect running with a few various Cuda Fortran programs, but I run into an error every time.
Using strace when running pgcollect produces the following line of interest:
$strace pgcollect -cuda test
stat("pgpaccnum.out", 0x7fffcaefc2e0) = -1 ENOENT (No such file or directory)
It then goes on to give the following error messages:
dwf_init: Unable to stat file
pgcollect-Fatal-/opt/pgi/linux86-64/10.6/bin/pgevtofq TERMINATED by signal 11
Arguments to /opt/pgi/linux86-64/10.6/bin/pgevtofq
/opt/pgi/linux86-64/10.6/bin/pgevtofq test pgprof.out
This file appears to be related to the PGI Accelerator, but it isn’t being used by my program. Any ideas as to what is causing this? Should this file be located somewhere or should it be generated?
We have a known issue in pgcollect 10.6 that you may be encountering.
If you invoke pgcollect with ‘-cuda’ and don’t specify any keywords such as ‘-cuda=gmem’, pgcollect fails to find the CUDA Fortran profiling config file it needs to generate a good profile. This will be fixed in PGI 10.8 in early August.
We will continue to look into the problem you reported with pgpaccnum.out, but please let us know if things start working better when you use this workaround.
target process has terminated, writing profile data
For the config file, I only included one simple counter, gridsize. Since I assumed that this was an issue that pgcollect was having with my CUDA Fortran program, I created a basic program to utilize the accelerator. The program compiled and ran fine, but it produced the same error when run under pgcollect.
Is there anything else that may be causing this problem? If you would like more information, such as strace results, let me know. Otherwise, each of these commands produces the same error messages.
We’ll continue looking at this issue, but so far we have not been able to reproduce it. Would you please file a problem report by emailing trs@pgroup.com? We can probably handle this more effectively through that channel.
