Both PGDBG and PGPROF require a 32-bit java in order to run the GUI’s. Hence, you can not use your system’s default java. Instead, please set the environment variable “PGI_JAVA” to the location of the PGI supplied version of Java which should have been install at the same time as your compilers.
Sorry if I was unclear before, but you can not run the PGDBG Java GUI with a 64-bit version of Java. Please use the version of Java that accompanies the compilers.
Our GUIs use the 32-bit JRE, which requires 32-bit X libs. Unfortunately, the error message from the JRE isn’t very illuminating. You’ll need to install, from your Fedora9 media, the following 32-bit packages:
hi mkcolg i have the debuger ready i just install the packages in the 32 bit directory and the debbuger works so now i want to know how can i link the pgdbg with my mpirun command
