pgf 9.0.3 installation on Fedora 11
Hi! mat
I’m trying to install pgf 9.0.3 workstation on my fedora 11.
First, glibc version is different. Is it ok to use the pgf?
and then, I make a path to PGI
[choingjoo@ARL-HUFS pgi]# setenv PGI /opt/pgi
[choingjoo@ARL-HUFS pgi]# set path=(/opt/pgi/linux86-64/9.0/bin $path)
[choingjoo@ARL-HUFS pgi]# setenv MANPATH “$MANPATH”:/opt/pgi/linux86-64/9.0/man
MANPATH: Undefined variable.
[choingjoo@ARL-HUFS pgi]# setenv LM_LICENSE_FILE “$LM_LICENSE_FILE”:/opt/pgi/license.dat
LM_LICENSE_FILE: Undefined variable.
There are some error message
[choingjoo@ARL-HUFS pgi]# touch x.f
[choingjoo@ARL-HUFS pgi]# pgf77 -V -c x.f
pgf77 9.0-3 64-bit target on x86-64 Linux -tp penryn-64
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2009, STMicroelectronics, Inc. All Rights Reserved.
PGFTN/x86-64 Linux 9.0-3
PGFTN-W-0006-Input file empty (x.f)
PGFTN/x86-64 Linux 9.0-3: compilation completed with warnings
[choingjoo@ARL-HUFS pgi]# pgf90 -V -c x.f
pgf90 9.0-3 64-bit target on x86-64 Linux -tp penryn-64
PGF90/x86-64 Linux 9.0-3
PGF90-W-0006-Input file empty (x.f)
PGF90/x86-64 Linux 9.0-3: compilation completed with warnings
[choingjoo@ARL-HUFS pgi]# touch x.c
[choingjoo@ARL-HUFS pgi]# pgCC -V -c x.c
pgCC 9.0-3 64-bit target on x86-64 Linux -tp penryn-64
Edison Design Group C/C++ Front End, version 3.6 (Aug 6 2009 16:54:27)
Copyright 1988-2006 Edison Design Group, Inc.
PGCC/x86 Linux 9.0-3
[choingjoo@ARL-HUFS pgi]# pgcc -V -c x.c
pgcc 9.0-3 64-bit target on x86-64 Linux -tp penryn-64
PGC/x86-64 Linux 9.0-3
PGC-W-0006-Empty translation unit (x.c)
PGC/x86-64 Linux 9.0-3: compilation completed with warnings
What should I do for figure it out?
thank you
Hi choingju,
It should be ok.
Warning #6 just means that the file you’re compiling is empty.
  • Mat
Thank you. Mat
So what can I do for fixing the warning #6 message?
Is it caused any problem to use pgf??
choingjoo
Hi choingjoo,
The is is nothing wrong with pgf. The compiler is just giving you a warning that the file you’re compiling does not contain any code and hence there is nothing to compile. When you compile a file with source code in it, then the warning will go away.
  • Mat
