I am trying to use an array that has been dynamically allocated, and although the compiler has no problem, during run time I get a segmentation fault error. I realize this is usually the error one receives when one is trying to access memory outside of what has been allocated, but I am not doing this. Can you find fault with the technique I am using here?
Here is my makefile:
PROGRAM = nautreverb
FC = /opt/pgi/linux86-64/6.1/bin/pgf77
FSRCS = nautreverb.f
FOBJS = $(FSRCS:.f=.o)
INCLUDE = -I. -L.
FFLAGS = -g
$(PROGRAM): $(FOBJS)
$(FC) $(FFLAGS) -o $@ $(INCLUDE) $(FOBJS)
clean:
rm *.o
And here is my code:
program nautreverb
implicit none
real*8 disttp(*)
integer nn, nxtot, nytot, nx, ny
integer*4 malloc
integer*4 dsize
pointer( disttp_ptr,disttp)
dsize = 8
nxtot = 10
nytot = 10
disttp_ptr = malloc(dsize*1001*1001)
nn=0
do 100 nx=1,nxtot
do 200 ny=1,nytot
nn=nn+1
write(*,*) nx,ny,nn
disttp(nn) = 1
write(*,*) disttp(nn)
200 continue
100 continue
end
The output is
1 1 1
Segmentation fault
Note that if I change the allocated arraysize to be dsize101101, the code works fine with no seg fault. This is also the case if I simply declare the array to be 1001*1001 instead of allocating. What is the problem?
Thanks,
Jennifer
