PGF90 10.X problem with "check bound" & zero s
Hello .
I have problem with the “-C” check bound option and zero size array
(The original code I’m debuging has 1 million of lines = Meso-NH , the French WRF ;-) )
When compiled with ( I have the last current version PFG9010.9 )
pgf90 -C -g test_real_dim0.f90 -o test_real_dim0
I at run time I go’t
test_real_dim0
TEST :: sub_print from MAIN
MAIN :: size(CSV)= 0 shape(CSV)= 0 lbound(CSV)= 1 ubound(CSV)= 0
PASSED :: sub_print from MAIN
TEST :: sub_print from sub_with_size
sub_with_size :: size(HSV)= 0 shape(HSV)= 0 lbound(HSV)= 1 ubound(HSV)= 0
PASSED :: sub_with_size
TEST :: sub_print from sub_no_size
sub_no_size :: size(HSV)= 0 shape(HSV)= 0 lbound(HSV)= 1 ubound(HSV)= 0
0: Subscript out of range for array hsv (test_real_dim0.f90: 40)
subscript=1, lower bound=1, upper bound=0, dimension=1
The test code show 3 ways of calling the F77 ( without interface ) “sub_print” routine with an array of size-zero
( in our code Meso-NH, the array is multidimensional, and the size is read from namelist file & could by zero depending of the algorithm used , and a lot of other variables as passed to the subroutine ) .
The first 2 call , from main program and , passing the size of the array work fine,
but the last one , calling from and “assume shape array” + size(array) generate the “out of range” …
This code run without problem with all other FORTRAN compiler & check bound I’ve tested , ifort/gfortran/g95 .
Thank you in advance .
Juan , fort the Meso-NH user support
Here is the test code
SUBROUTINE sub_print(KSV,HSV)
  IMPLICIT NONE
  INTEGER               :: KSV       ! number of scalars
  REAL, DIMENSION(KSV)  :: HSV
  INTEGER :: I
  !print*," => OK :: sub_print KSV=",KSV
  DO i=1,KSV
     PRINT*,"i,HSV",i,HSV
  END DO
END SUBROUTINE sub_print
MODULE mode_sub
CONTAINS
  SUBROUTINE sub_with_size(KSV,HSV)
    IMPLICIT NONE
    REAL, DIMENSION(KSV), INTENT(IN)  :: HSV
    write(*,'("  sub_with_size :: size(HSV)= ",I4," shape(HSV)=",I4 ," lbound(HSV)=",I4," ubound(HSV)=",I4)') &
           size(HSV), shape(HSV), lbound(HSV),  ubound(HSV)
    CALL sub_print(KSV,HSV)
  END SUBROUTINE sub_with_size
  SUBROUTINE sub_no_size(HSV)
    IMPLICIT NONE
    REAL, DIMENSION(:), INTENT(IN)  :: HSV
    write(*,'("  sub_no_size   :: size(HSV)= ",I4," shape(HSV)=",I4 ," lbound(HSV)=",I4," ubound(HSV)=",I4)') &
    CALL sub_print(SIZE(HSV),HSV)
  END SUBROUTINE sub_no_size
END MODULE mode_sub
PROGRAM test_dim0
USE mode_sub
IMPLICIT NONE
INTEGER                          :: ISV       ! number of scalars
REAL, DIMENSION(:), ALLOCATABLE  :: CSV
ISV = 0
ALLOCATE (CSV(ISV))
CSV = 1.0
print*," TEST   :: sub_print from MAIN "
write(*,'("  MAIN          :: size(CSV)= ",I4," shape(CSV)=",I4 ," lbound(CSV)=",I4," ubound(CSV)=",I4)') &
          size(CSV), shape(CSV), lbound(CSV),  ubound(CSV)
CALL sub_print(ISV,CSV)
print*," PASSED :: sub_print from MAIN " ; print*
print*," TEST   :: sub_print from sub_with_size  "
CALL sub_with_size(ISV,CSV)
print*," PASSED :: sub_with_size  " ; print*
print*," TEST    :: sub_print from sub_no_size  "
CALL sub_no_size(CSV)
print*," PASSED :: sub_no_size  " ; print*
END PROGRAM test_dim0
Hello, it’s me again .
I’ve bypassed some of the previous problem in mono-processor execution ( deactivating the ‘-C’ for some routines )
But now I go a similare problem on (MPI) multi-processor runs with boundary array ( of zero-size , for processors not in the physical boundarys ) …
So a more simple test example of the same problem with , check bound + zero-size array , this time with multi-dimensional array .
pgf90 -C -g test_real_multi_dim0.f90 -o test_real_multi_dim0
TEST :: sub_no_size
0: Subscript out of range for array boundary (test_real_multi_dim0.f90: 39)
With ifort no problem :
ifort -C -g test_real_multi_dim0.f90 -o test_real_multi_dim0
TEST :: sub_no_size
==> sub_no_size : no boundary
The test_real_multi_dim0.f90 file
MODULE mode_sub
CONTAINS
    IMPLICIT NONE
    IF (size(HSV) .EQ. 0 ) THEN
       print*," ==> sub_no_size : no boundary "
    ELSE
       print*," ==> sub_no_size : boundary , DO some WORK  "
    END IF
END MODULE mode_sub
PROGRAM test_multi_dim0
USE mode_sub
IMPLICIT NONE
INTEGER                            :: NX,NZ      ! dims
REAL, DIMENSION(:,:), ALLOCATABLE  :: BOUNDARY
NX = 0   ! MPI domain decomposiotn , some proc have no boundary !!!
NZ = 10
ALLOCATE(BOUNDARY(NX,NZ))
BOUNDARY = 1.0
print*," TEST    :: sub_no_size  "
CALL sub_no_size(BOUNDARY(:,NZ))
END PROGRAM test_multi_dim0
Thank you .
Juan
Hi Juan,
Thanks for the report. It does appear that the bounds checking is in error. I have created a technical problem report (TPR#17399) and sent on to our engineers for further investigation.
Best Regards,
Mat
:-) OK Thank you Mat ( ;-) more are coming soon )
Juan
Juan,
TPR 17399 - Checking the bounds of zero-size arrays
has been corrected in the 11.0 release, which is now available.
Thanks again for your submission.
regards,
dave
:-) Thank you Dave & Bonne Année
I’m testing this new version right now …
Bye
Juan
