Attempting to build code with the PGI (10.2.0) compiler on a Cray XT5 I get the following error:
PGF90-S-0038-Symbol, netcdf, has not been explicitly declared (/tmp/work/underwoo/testing/CM2.1U_Control-1990_E1.M_3A/src/shared/diag_manager/diag_output.F90: 455)
This code is part of a coupled climate model that builds and runs when using the Pathscale and Intel compiler suites.
The file quoted in the error message uses ‘IMPLICIT NONE’, and also has ‘INTEGER, PARAMETER :: NETCDF’’. Also, this variable ‘NETCDF’ is only used twice in this file. Interestingly, if the symbol is renamed everywhere from NETCDF -> NETCDF1 the source will compile.
Is there any reason PGI would issue this error even when the symbol is defined? (Again, Pathscale and Intel compilers do not issue a warning or error for this file.)
Code snippet:
MODULE diag_output_mod
USE mpp_io_mod, ONLY: axistype, fieldtype, mpp_io_init, mpp_open, mpp_write_meta,&
& mpp_write, mpp_flush, mpp_close, mpp_get_id, MPP_WRONLY, MPP_OVERWR,&
& MPP_NETCDF, MPP_MULTI, MPP_SINGLE
USE mpp_domains_mod, ONLY: domain1d, domain2d, mpp_define_domains, mpp_get_pelist,&
& mpp_get_global_domain, mpp_get_compute_domains, null_domain1d, null_domain2d,&
& OPERATOR(/=), mpp_get_layout, OPERATOR(==)
USE mpp_mod, ONLY: mpp_npes, mpp_pe
USE diag_axis_mod, ONLY: diag_axis_init, get_diag_axis, get_axis_length,&
& get_axis_global_length, get_domain1d, get_domain2d, get_axis_aux, get_tile_count
USE diag_data_mod, ONLY: diag_fieldtype, diag_global_att_type
USE time_manager_mod, ONLY: get_calendar_type, valid_calendar_types
USE fms_mod, ONLY: error_mesg, mpp_pe, write_version_number, FATAL
USE platform_mod, ONLY: r8_kind
IMPLICIT NONE
PRIVATE
PUBLIC :: diag_output_init, write_axis_meta_data, write_field_meta_data, done_meta_data,&
& diag_field_out, diag_flush, diag_fieldtype, get_diag_global_att, set_diag_global_att
TYPE(diag_global_att_type), SAVE :: diag_global_att
INTEGER, PARAMETER :: NETCDF = 1
INTEGER, PARAMETER :: mxch = 128
INTEGER, PARAMETER :: mxchl = 256
INTEGER :: current_file_unit = -1
INTEGER, DIMENSION(2,2) :: max_range = RESHAPE((/ -32767, 32767, -127, 127 /),(/2,2/))
INTEGER, DIMENSION(2) :: missval = (/ -32768, -128 /)
INTEGER, PARAMETER :: max_axis_num = 20
INTEGER :: num_axis_in_file = 0
INTEGER, DIMENSION(max_axis_num) :: axis_in_file
LOGICAL, DIMENSION(max_axis_num) :: time_axis_flag, edge_axis_flag
TYPE(axistype), DIMENSION(max_axis_num), SAVE :: Axis_types
LOGICAL :: module_is_initialized = .FALSE.
CHARACTER(len=128), PRIVATE :: version= &
'$Id: diag_output.F90,v 17.0.8.1 2010/03/03 14:47:42 sdu Exp $'
CHARACTER(len=128), PRIVATE :: tagname= &
'$Name: riga_patch_sdu $'
CONTAINS
SUBROUTINE diag_output_init(file_name, FORMAT, file_title, file_unit,&
& all_scalar_or_1d, domain)
CHARACTER(len=*), INTENT(in) :: file_name, file_title
INTEGER , INTENT(in) :: FORMAT
INTEGER , INTENT(out) :: file_unit
LOGICAL , INTENT(in) :: all_scalar_or_1d
TYPE(domain2d) , INTENT(in) :: domain
! real(KIND=r8_kind), dimension(1) :: tdata
INTEGER :: form, threading, fileset
TYPE(diag_global_att_type) :: gAtt
!---- initialize mpp_io ----
IF ( .NOT.module_is_initialized ) THEN
CALL mpp_io_init ()
module_is_initialized = .TRUE.
END IF
CALL write_version_number( version, tagname )
!---- set up output file ----
SELECT CASE (FORMAT)
CASE (NETCDF)
form = MPP_NETCDF
threading = MPP_MULTI
fileset = MPP_MULTI
CASE default
! <ERROR STATUS="FATAL">invalid format</ERROR>
CALL error_mesg('diag_output_init', 'invalid format', FATAL)
END SELECT
--*--*--*-- NETCDF not used anywere else if file --*--*--*--
