PGF90-S-0084-Illegal use of symbol - not public entity ..
when compiling the ECHAM5(Linux-x64+PGI7.0), a following error occurs.
PGF90-S-0084-Illegal use of symbol local_decomposition - not public entity of module (mo_chem_bcond_io.f90: 54)
0 inform, 0 warnings, 1 severes, 0 fatal for xt_read_emiss_fields_so2
Any suggestion will be appreciated.
Hi terry1012,
I’d like to have you try compiling with the latest PGI compilers (9.0). While I don’t see an error report specific to ECHAM5, I do see a similar issue where we weren’t exporting predefined symbols such as generic correctly in the 7.0 release. (TPR#4090)
For example:
> > cat test.f90
module m
intrinsic max
end module m
program test
use m, ren => max
end program test
> > pgf90 test.f90
PGF90-S-0084-Illegal use of symbol max - not public entity of module (test.f90: 6)
0 inform, 0 warnings, 1 severes, 0 fatal for test
While it could be unrelated, I know of other users who have compiled ECHAM5 successfully with later version of the compilers. Unfortunately, I don’t have access to ECHAM5 myself, otherwise, I would verify this for you.
Hope this helps,
Mat
Hi, Mat
I have tried PGI9.0 and the error remains.
Does it probably caused by incorrect load of MPI library or sth. else?
3ks!
Hi Terry,
Another engineer here had echam-5.5.00_rc1 and I was able to compile it without issue with 9.0. So either there is a problem with the source code you have or there is something wrong in your environment.
Which version of ECHAM do you have? Could your modules be old?
  • Mat
Hi, Mat,
My code is not just ECHAM but ECHAM-HAM and the error occured in the HAM module. I could also compile successfully the ECHAM model only.
Could you give me your Email address so that I can send the original code to you and you can have a further check about the PGI?
Thank you!
Terry
Hi Terry,
Please send a reproducing example to PGI Customer Service (trs@pgroup.com) and ask them to forward it to me. I’ll what I can determine.
Thanks,
Mat
Hi there,
How was this problem solved?
I am facing it too.
Thanks,
Genito
Hi there,
I am facing it too with PGI v9
Thanks,
Genito
Hi Genito,
I don’t have a record of Terry sending me this code so I’m not sure if or what was done to fix it. I also looked through our issue tracking system but found no reference to ECHAM-HAM.
Can you send me (via trs) a reproducing case?
Thanks,
Mat
This problem occurs when compiling ECHAM + HAM1 and
is solved by adding the following lines
             USE mo_decomposition,     ONLY: gc => global_decomposition,   &
                                  dc => local_decomposition
at the beginning of module mo_chem_bcond_io, at line 14, after
USE mo_aero_mem,    ONLY: input
This was fixed in later versions of HAM, e.g. ECHAM 5.5+HAM2.
Regards, Jost
