I am using the following compiler
pgfortran 15.5-0 64-bit target on Apple OS/X -tp haswell
and getting the following error when porting the function below using OpenAcc.
PGF90-S-0155-Compiler failed to translate accelerator region (see -Minfo messages): Load of NULL symbol (kernel/coordinate_jacobian_mod.F90: 1)
coordinate_jacobian:
32, Generating acc routine gang
53, !$acc loop gang ! blockidx%x
54, !$acc loop worker ! threadidx%y
!$acc loop vector ! threadidx%x
56, !$acc loop vector ! threadidx%x
63, !$acc loop worker ! threadidx%y
52, Loop is parallelizable
53, Loop is parallelizable
54, Loop is parallelizable
55, Loop carried reuse of jac prevents parallelization
56, Loop is parallelizable
63, Loop is parallelizable
0 inform, 0 warnings, 1 severes, 0 fatal for coordinate_jacobian
make[2]: *** […/…/build/dynamo/kernel/coordinate_jacobian_mod.mod] Error 2
20 !> @brief Subroutine Computes the element Jacobian of the coordinate transform from
21 !! reference space \hat{\chi} to physical space \chi assuming the coordinate
22 !! field is in W0
23 !! @param[in] ndf Integer. The size of the chi arrays
24 !! @param[in] ngp_h Integer. The number of quadrature points in horizontal direction
25 !! @param[in] ngp_v Integer. The number of quadrature points in vertical direction
26 !! @param[in] chi_1 Real 1-dim array. Holds the chi_1 coordinate field
27 !! @param[in] chi_2 Real 1-dim array. Holds the chi_2 coordinate field
28 !! @param[in] chi_3 Real 1-dim array. Holds the chi_3 coordinate field
29 !! @param[in] diff_basis Real 5-dim array. holds the the grad of W0 basis functions
30 !! @param[out] jac Real 5-dim array. Holds the values of the Jacobian on quadrature points
31 !! @param[out] dj Real 3-dim array Holds the values of the determinant of the Jacobian on quadrature points
32 subroutine coordinate_jacobian(ndf, ngp_h, ngp_v, chi_1, chi_2, chi_3, diff_basis, jac, dj)
33 !-------------------------------------------------------------------------------
34 ! Compute the Jacobian J^{i,j} = d chi_i / d \hat{chi_j} and the
35 ! derterminant det(J)
36 !-------------------------------------------------------------------------------
37 !$acc routine gang
38 integer, intent(in) :: ndf, ngp_h, ngp_v
39 real(kind=r_def), intent(in) :: chi_1(ndf), chi_2(ndf), chi_3(ndf)
40 real(kind=r_def), intent(in) :: diff_basis(3,ndf,ngp_h,ngp_v)
41 real(kind=r_def), intent(out) :: jac(3,3,ngp_h,ngp_v)
42 real(kind=r_def), intent(out) :: dj(ngp_h,ngp_v)
43
44 ! Hardwired values for cartesian domain
45 real(kind=r_def) :: dx = 6000.0_r_def, &
46 dy = 1000.0_r_def, &
47 dz = 2000.0_r_def
48
49 integer :: i, j, df, dir
50
51
52 do j = 1,ngp_v
53 do i = 1,ngp_h
54 jac(:,:,i,j) = 0.0_r_def
55 do df = 1,ndf
56 do dir = 1,3
57 jac(1,dir,i,j) = jac(1,dir,i,j) + chi_1(df)*diff_basis(dir,df,i,j)
58 jac(2,dir,i,j) = jac(2,dir,i,j) + chi_2(df)*diff_basis(dir,df,i,j)
59 jac(3,dir,i,j) = jac(3,dir,i,j) + chi_3(df)*diff_basis(dir,df,i,j)
60 end do
61 end do
62 ! Hard wired values for cartesian biperiodic domain this needs correcting
63 jac(:,:,i,j) = 0.0_r_def
64 jac(1,1,i,j) = dx !6000.0_r_def
65 jac(2,2,i,j) = dy !1000.0_r_def
66 jac(3,3,i,j) = dz !2000.0_r_def
67
68 dj(i,j) = jac(1,1,i,j)*(jac(2,2,i,j)*jac(3,3,i,j) &
69 - jac(2,3,i,j)*jac(3,2,i,j)) &
70 - jac(1,2,i,j)*(jac(2,1,i,j)*jac(3,3,i,j) &
71 - jac(2,3,i,j)*jac(3,1,i,j)) &
72 + jac(1,3,i,j)*(jac(2,1,i,j)*jac(3,2,i,j) &
73 - jac(2,2,i,j)*jac(3,1,i,j))
74 end do
75 end do
76
77 end subroutine coordinate_jacobian
The error goes away if I replace the lines(64,65,66) below by replacing the variables by constants.
jac(1,1,i,j) = 6000.0_r_def
jac(2,2,i,j) = 1000.0_r_def
jac(3,3,i,j) = 2000.0_r_def
