Hi all,
I get the following interesting message when compiling:
pgf90-Fatal-/opt/pgi/linux86-64/13.10/bin/pgf902 TERMINATED by signal 11
Arguments to /opt/pgi/linux86-64/13.10/bin/pgf902
/opt/pgi/linux86-64/13.10/bin/pgf902 /tmp/pgf90tYdd5F98I082.ilm -fn myfile.f90 -opt 2 -terse 1 -inform warn -x 51 0x20 -x 119 0xa10000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 127 17 -x 19 0x400000 -x 28 0x40000 -x 120 0x10000000 -x 70 0x8000 -x 122 1 -x 125 0x20000 -quad -vect 56 -y 34 16 -x 34 0x8 -x 32 12582912 -y 19 8 -y 35 0 -x 42 0x30 -x 39 0x40 -x 199 10 -x 39 0x80 -x 34 0x400000 -x 149 1 -x 150 1 -x 59 4 -x 59 4 -tp nehalem -x 120 0x1000 -x 124 0x1400 -y 15 2 -x 57 0x3b0000 -x 58 0x48000000 -x 49 0x100 -x 120 0x200 -astype 0 -x 121 1 -x 124 1 -accel nvidia -x 163 0x1 -x 186 0x80000 -x 180 0x400 -x 180 0x4000000 -x 189 0x80000 -x 163 0x100 -x 163 0x200 -x 176 0x140000 -x 177 0x0202007f -x 176 0x100 -x 186 0x10000 -x 176 0x100 -x 186 0x20000 -x 176 0x100 -x 176 0x100 -x 189 4 -x 189 0x800 -y 70 0x40000000 -x 186 0x80000 -x 180 0x400 -x 180 0x4000000 -x 163 0x100 -y 70 0x40000000 -y 189 0x4000000 -x 0 0x1000000 -x 2 0x100000 -x 0 0x2000000 -x 161 16384 -x 162 16384 -x 137 1 -x 180 0x4000000 -x 176 0x140000 -x 177 0x0202007f -x 176 0x100 -x 186 0x10000 -x 176 0x100 -x 186 0x20000 -x 176 0x100 -x 176 0x100 -x 189 4 -x 189 0x800 -x 189 0x80000 -x 68 0x1 -x 135 1 -x 68 0x1 -x 9 1 -x 42 0x14200000 -x 72 0x1 -x 136 0x11 -quad -x 119 0x10000000 -x 129 0x40000000 -x 129 2 -x 164 0x1000 -cmdline '+pgf90 Pij_GPU_Acc.f90 -ta=nvidia,fastmath,cuda5.5 -acc -Minfo=accel -lcublas -Mcuda=cuda5.5 -Mlarge_arrays -mcmodel=medium -fast -Mvect=sse -Mcache_align -Mflushz -Mpre -c' -asm /tmp/pgf90BYddrqaHWqKK.sm
This happens when I change this
!$acc kernels loop independent gang (256) private(rhs)
do b = 1, nb
! some code
!$acc loop independent vector (32)
do n = 1, nn
! some code
do i = 1, ni
!some code
enddo
! some code
enddo
!some code
do i = 1,i2
temp = 0.0
!$acc loop independent reduction(+:temp)
do k = 1,j2
temp = temp + x(i,k,r) * y(k)
end do
z(i+i1-1) = temp
end do
enddo
to this
do b = 1, nb
! some code
do n = 1, nn
! some code
do i = 1, ni
!some code
enddo
! some code
enddo
!some code
!$acc loop independent worker (32)
do i = 1,i2
temp = 0.0
!$acc loop independent vector (32) reduction(+:temp)
do k = 1,j2
end do
z(i+i1-1) = temp
end do
enddo
The weird thing is according to Minfo messages it seems to be dying much earlier in the compilation than this. Unfortunately, I may not post the full source - I’m not sure I’ll be able to produce a sanitized example in this case.
Any ideas?
Rob
ps - feel free to wack me over the head if I’m misusing gang/worker/vector statements. I’m just experimenting at this point to figure out how they best go together.
