This is an update to “pgfortran 13.7 incorrect record mark”, which was given
TPR #19513.
My reproducer shows the problem has not been fixed if you use the “-byteswapio”
flag. Here it is in full.
PROGRAM MKGRID
C
C Illustrating a problem with pgfortran 13.10 and the last record mark
C in an unformatted file when compiling with -byteswapio.
C Compile via: pgfortran -byteswapio mkgrid.f -o mkgrid
C Run via: mkgrid
C You get a file grid.in, size 224020.
C With "od -x grid.in | head -2" I see (on a Xeon E5-2630)
C 0000000 0000 0c00 0000 3d00 0000 3300 0000 0300
C 0000020 0000 0c00 0300 f86a 0000 0000 0000 0000
C and "od -x grid.in | tail -4" produces for me
C 0604740 0040 0000 0000 0000 0040 0000 0000 0000
C *
C 0665420 fd00 0795
C 0665424
C
C Note that the first record of the file contains 3 integers, so
C 12 bytes, and the record mark is accordingly 0C byte-swapped.
C The second record of the file contains 61*51*3*3=27999 8-byte
C reals, a total of 223992 bytes (hex 36AF8), record mark is 36AF8
C byte-swapped. But the last record mark is not 36AF8. This incorrect
C record mark will cause problems with a code that uses BACKSPACE, for example.
C
C This problem does not occur if you omit the "-byteswapio" flag.
C
C pgfortran -V (13.10) returns:
C pgfortran 13.10-0 64-bit target on x86-64 Linux -tp sandybridge
C
IMPLICIT NONE
INTEGER, PARAMETER :: JD=61,KD=51,LD=3
C
CALL DOIT(JD,KD,LD)
END
C*********************************************************
SUBROUTINE DOIT(JD,KD,LD)
IMPLICIT NONE
INTEGER, INTENT(IN) :: JD,KD,LD
C
REAL(8) :: X(JD,KD,LD),Y(JD,KD,LD),Z(JD,KD,LD)
INTEGER :: J,K,L
C
C
DO L = 1,LD
DO K = 1,KD
DO J = 1,JD
X(J,K,L) = REAL(J-1,8)
Y(J,K,L) = REAL(K-1,8)
Z(J,K,L) = REAL(L-1,8)
ENDDO
ENDDO
ENDDO
C
OPEN(UNIT=2,FILE='grid.in',STATUS='UNKNOWN',FORM='UNFORMATTED')
WRITE(2) JD,KD,LD
WRITE(2) X,Y,Z
CLOSE(UNIT=2)
C
RETURN
END
