pgfortran 17.10: strange message "iliutil.c: case IL_KI
when compiling some simple Fortran code with an ISHIFT call with pgfortran 17.10:
   subroutine shift(s)
      integer(8) :: s
      s=ishft(s,21)
   end subroutine
I see the output:
iliutil.c: case IL_KISHFT:
Do I need to worry about this, or is this just some kind of compiler debugging output that was forgotten to be disabled for the last release?
I did not see this with 17.04, but in fact I saw the same thing with flang for a while (but not any more):
https://github.com/flang-compiler/flang/issues/145
Cheers,
Janus
The problem has been logged as TPR 24918. I believe someone instrumented the compiler with a print stmt to track a problem, and failed to remove it afterwards.
I think you can ignore it, and engineering will correct me if I am wrong.
thanks,
dave
The problem you reported
24918 - Compiler outputting extra verbiage with ishft “iliutil.c: case IL_KISHFT:”
has been fixed in the current 18.1 release.
dave
Thank you!
