I wrote a fortran cuda code include a lot of device subroutines. When I tried to compile it, the compiler runs very slow and stop there forever. How can I deal with this? Thank you.
module test
integer,device :: nlayer,nfield,nsource
real,device :: xfreq,mur(6),xloc(6),tolerance1,tolerance2,xpi,xmu0,xepsilon0,xomega,k_max
complex,device :: cer(6),ck(6),ci
logical,device :: pec_first,pec_last
real xx(20),xy(20),xz(20)
parameter(nlayer=6)
parameter(nfield=1)
parameter(nsource=5)
parameter(pec_first=.false.)
parameter(pec_last=.false.)
parameter(xfreq=4.739336e+14)
parameter(tolerance1=1.0e-5)
parameter(tolerance2=1.0e-3)
parameter(xpi=acos(-1.0))
parameter(xepsilon0=8.854187817e-12)
parameter(xmu0=4.0e-7*xpi)
parameter(ci=(0,1))
parameter(k_max=3.1410636E+07)
parameter(xomega=2.0*xpi*xfreq)
contains
attributes(global) subroutine GreensFunction_CompEJ(Test_Green,&
& xx,xy,xz,xxs,xys,xzs,Nxx,Nyy,Nxz)
implicit none
real krhomax
parameter(krhomax=1.0e32)
integer N,N1
real xL1,wrho
real dk,dk1,kpmax,dk2
integer Nxx,Nyy,Nxz,Nrect,i_temp
logical Test_Green
real xxs,xys,xzs
integer i,j,k,counter,s
real theta1, theta2
real xr,xconst1,xconst2,xconst3,xrho,zzp,yzb,rt1,rt2
complex ca(200),cb(200),cG(9),prim,tyu2,zyu,yyu
complex ki,tyu,xyu,cons
complex Gxxpm,Gxzpm,Gzxpm,Gxypm,Gzzpm,Gyypm
complex Gyxpm,Gyzpm,Gzypm
complex xxu,zzu,ki2,cons2,zyu2,prim2
complex Gxx_minus,Gxy_minus,Gxz_minus,Gzy_minus
complex Gyy_minus,Gzx_minus,Gzz_minus,Gyz_minus
! open(93,file='GEJxx.dat',status='unknown')
! open(94,file='GEJzx.dat',status='unknown')
! open(95,file='GEJyy.dat',status='unknown')
! open(97,file='GEJxz.dat',status='unknown')
! open(98,file='GEJxy.dat',status='unknown')
! open(99,file='GEJzz.dat',status='unknown')
! open(91,file='GEJyx.dat',status='unknown')
! open(92,file='GEJyz.dat',status='unknown')
! open(90,file='GEJzy.dat',status='unknown')
counter=0
if (Test_Green .eqv. .true.) then
do 201 i=1,Nxx
xconst1=(xx(i)-xxs)**2
do 202 j=1,Nyy
xconst2=(xy(j)-xys)**2
xrho=sqrt((xx(i)-xxs)**2+(xy(j)-xys)**2)
if (xrho .eq. 0.0) then
theta1=0.0
theta2=0.0
else
theta1=acos(((xx(i)-xxs))/xrho)
theta2=asin(((xy(j)-xys))/xrho)
end if
rt1=sin(theta2)*sin(theta2)
rt2=cos(theta1)*cos(theta1)
do 203 k=1,Nxz
xconst3=(xz(k)-xzs)**2
xr=sqrt(xconst1+xconst2+xconst3)
call LayerNo2(xzs,nsource,xloc,nlayer)
call LayerNo2(xz(k),nfield,xloc,nlayer)
cons=1.0/(xomega**2*xmu0*xepsilon0*cer(nsource))
cons2=1.0/(xomega**2*xmu0*xepsilon0*cer(nfield))
s=-1
if (xz(k) .lt. xzs) s=1
if (nsource .eq. nfield) then
yzb=xconst2+(xz(k)-xzs)**2
zzp=abs(xz(k)-xzs)
ki=ck(nsource)
ki2=ck(nfield)
prim=exp(-ci*ki*xr)/(4*xpi*xr)*cons
prim2=exp(-ci*ki*xr)/(4*xpi*xr)*cons2
zyu=(3+3*ci*ki2*xr-(ki2*xr)**2)/xr**4
zyu2=-(1.0+ci*ki2*xr)/xr**2
tyu=(3+3*ci*ki*xr-(ki*xr)**2)/xr**4
tyu2=-(1.0+ci*ki*xr)/xr**2
xxu=xconst1*tyu+tyu2
yyu=xconst2*tyu+tyu2
xyu=(xx(i)-xxs)*(xy(j)-xys)*tyu
zzu=xconst3*tyu+tyu2
Gxx_minus=(ki**2+xxu)*prim
Gxy_minus= xyu*prim
Gxz_minus=-s*(xx(i)-xxs)*zzp*prim*tyu
Gyy_minus=(ki**2+yyu)*prim
Gyz_minus=-s*(xy(j)-xys)*zzp*prim*tyu
Gzx_minus=-s*(xx(i)-xxs)*zzp*prim*tyu
Gzy_minus=-s*(xy(j)-xys)*zzp*prim*tyu
Gzz_minus=(ki**2+zzu)*prim2
else
Gxx_minus=0.0
Gyy_minus=0.0
Gxy_minus=0.0
Gxz_minus=0.0
Gzx_minus=0.0
Gzy_minus=0.0
Gzz_minus=0.0
Gyz_minus=0.0
end if
! print*,'xzs,xz(k)',xzs,xz(k)
! print*,'nsource',nsource
kpmax=1.2*real(k_max)
wrho=xrho
if (xrho .lt. 3.0e6/xfreq) wrho=3.0e6/xfreq
dk=0.1*xpi/wrho
dk2=xpi/wrho
if (dk .gt. kpmax) then
dk1=kpmax/2
N1=1
else
N1=(1+int(kpmax/dk))
dk1=0.5*kpmax/N1
endif
xL1=0.6*k_max
N=200
ca(1)=0.0
if (N1 .eq. 1) then
cb(1)=dk1+ci*xL1
cb(2)=kpmax
ca(2)=cb(1)
do i_temp=2,N
ca(i_temp+1)=cb(i_temp)
cb(i_temp+1)=cb(i_temp)+dk
end do
else
do i_temp=1,N1
cb(i_temp)=i_temp*(dk1+ci*xl1/N1)
cb(N1+i_temp)=kpmax/2+ci*xL1+i_temp*(dk1-ci*xl1/N1)
ca(N1+i_temp+1)=cb(N1+i_temp)
end do
cb(2*N1+1)=real(cb(2*N1)+dk)
do i_temp=2*N1,N
ca(i_temp+1)=real(cb(i_temp))
cb(i_temp+1)=real(cb(i_temp)+dk2)
end do
end if
Nrect=N1+3
call GreenOnePointEJ(xrho,xz(k),xzs,ca,cb,cG,Nrect)
counter=counter+1
Gxxpm=(Gxx_minus+rt1*(cG(1)+cG(6))+rt2*(cG(2)+cG(7)))
Gxzpm=(Gxz_minus+cG(3)*cos(theta1))
Gyzpm=(Gyz_minus+cG(3)*sin(theta2))
Gzxpm=(Gzx_minus-cG(4)*cos(theta1))
Gzypm=(Gzy_minus-cG(4)*sin(theta2))
Gxypm=(Gxy_minus+(cG(9)-cG(8))*sin(theta2)*cos(theta1))
Gyxpm=Gxypm
Gzzpm=(Gzz_minus+cG(5))
Gyypm=(Gyy_minus+rt2*(cG(1)+cG(6))+rt1*(cG(2)+cG(7)))
! write(90,'(e16.7,1x,e16.7)')Gzypm/mur(nsource)
! write(93,'(e16.7,1x,e16.7)')Gxxpm/mur(nsource)
! write(94,'(e16.7,1x,e16.7)')Gzxpm/mur(nsource)
! write(95,'(e16.7,1x,e16.7)')Gyypm/mur(nsource)
! write(97,'(e16.7,1x,e16.7)')Gxzpm/mur(nsource)
! write(98,'(e16.7,1x,e16.7)')Gxypm/mur(nsource)
! write(99,'(e16.7,1x,e16.7)')Gzzpm/mur(nsource)
! write(91,'(e16.7,1x,e16.7)')Gyxpm/mur(nsource)
! write(92,'(e16.7,1x,e16.7)')Gyzpm/mur(nsource)
203 continue
202 continue
201 continue
end if
! close(90)
! close(91)
! close(92)
! close(93)
! close(94)
! close(95)
! close(96)
! close(97)
! close(98)
! close(99)
return
end
!**************************Spectral*****************************************************************
attributes(device) subroutine Spectral(xdrho,ckrho,xz,xzs,ns,nf,&
& iitem,iitep,ivtem,ivtep,vitem,vitep,vvtem,vvtep,&
& iitmm,iitmp,ivtmm,ivtmp,vitmm,vitmp,vvtmm,vvtmp)
implicit none
integer nlayermax,nsegmax,nmax,nAJ,nEJ,nHJ,nIntPoint
parameter(nlayermax=12,nsegmax=20000,nmax=2000)
parameter(nAJ=6,nEJ=9,nHJ=8,nIntPoint=32)
integer :: gejtest,ghjtest,gatest,nlayer,nfield,nsource,intno,xaxis,xzdir, gf_form
real :: xfreq,xxsp,xysp,xzsp,xxfp,xyfp,xzfp,intstart,intend,mur(12),xsig(12),xloc(12),tolerance1,tolerance2,xpi,xmu0,xepsilon0,xomega,theta,k_max
complex :: cer(12),ck(12),ci
logical :: pec_first,pec_last
integer ns,nf,sign2
real xz,xzs,xzcall,sign,xdrho
complex ckrho,ckrho2,kz_s,kz_f
complex iitem,iitep,ivtem,ivtep,vitem,vitep,vvtem,vvtep
complex iitmm,iitmp,ivtmm,ivtmp,vitmm,vitmp,vvtmm,vvtmp
complex cR_leftTE,cR_leftTM,cR_rightTE,cR_rightTM
complex cRTTMV,cRTTMI,cRTTEV,cRTTEI
complex cLTTEV,cLTTMV,cLTTMI,cLTTEI
complex cRRTE,cRRTM,cD0TE,cD0TM,cfphi0
complex tev,tei,tmv,tmi
complex fn0A,fn1A,fn2A,fn3A,fn4A,fn5A
complex ft0, ft1,ft2,ft3,ft4,ft5,pt0
complex rte1,rte2,rte3,rte4
complex rtm1,rtm2,rtm3,rtm4
complex ztes, ztms,ztef, ztmf
complex kzsf, epssf, musf
ckrho2=ckrho**2
kz_s=csqrt(ck(ns)**2-ckrho2)
call process_ckz(kz_s)
if (ns .eq. nf) then
kz_f=kz_s
else
kz_f=csqrt(ck(nf)**2-ckrho2)
call process_ckz(kz_f)
end if
ztmf=kz_f/(xomega*xepsilon0*cer(nf))
ztms=kz_s/(xomega*xepsilon0*cer(ns))
ztef=xomega*xmu0*mur(nf)/kz_f
ztes=xomega*xmu0*mur(ns)/kz_s
kzsf=kz_s/kz_f
epssf=cer(ns)/cer(nf)
musf=mur(ns)/mur(nf)
ckrho2=ckrho**2
if (nf .gt. ns) then
xzcall=xloc(ns)
else if (nf .lt. ns) then
xzcall=xloc(ns-1)
else
xzcall=xz
end if
sign=-1.0
if (xz .gt.xzs) sign=1.0
sign2=1
if (xzcall .lt. xzs) sign2=-1
pt0=exp(-ckrho*abs(xz-xzs))
call fun0A(kz_s,xz,xzs,ci,fn0A)
ft0=fn0A
call fun1A(kz_s,xzcall,xzs,sign2,ci,fn1A)
ft1=fn1A
call fun2A(kz_s,xzcall,xzs,ns,sign2,xloc,ci,fn2A)
ft2=fn2A
call fun3A(kz_s,xzcall,xzs,ns,sign2,xloc,ci,fn3A)
ft3=fn3A
call fun4A(kz_s,xzcall,xzs,ns,sign2,xloc,ci,fn4A)
ft4=fn4A
call fun5A(kz_s,xzcall,xzs,ns,sign2,xloc,ci,fn5A)
ft5=fn5A
call R_right(ckrho2,xz,ns,nf,&
& cR_rightTE,cR_rightTM,cRTTEV,cRTTMV,cRTTEI,cRTTMI)
call R_left(ckrho2,xz,ns,nf,&
& cR_leftTE,cR_leftTM,cLTTEV,cLTTMV,cLTTEI,cLTTMI)
if (ns .eq. 1) then
!The source is in the first layer
ft2=0.0
ft4=0.0
ft5=0.0
cfphi0=0.0
cR_leftTE=0.0
cR_leftTM=0.0
else if (ns .eq. nlayer) then
!The source is in the last layer
ft3=0.0
ft4=0.0
ft5=0.0
cfphi0=0.0
cR_rightTE=0.0
cR_rightTM=0.0
else
!The source is neither in the first layer nor in the last layer
cfphi0=exp(-ci*2*kz_s*(xloc(ns)-xloc(ns-1)))
end if
cRRTE=cR_rightTE*cR_leftTE
cD0TE=1-cRRTE*cfphi0
cRRTM=cR_rightTM*cR_leftTM
cD0TM=1-cRRTM*cfphi0
rtm1=cR_leftTM*ft2/cD0TM
rtm2=cR_rightTM*ft3/cD0TM
rtm3=cRRTM*ft4/cD0TM
rtm4=cRRTM*ft5/cD0TM
rte1=cR_leftTE*ft2/cD0TE
rte2=cR_rightTE*ft3/cD0TE
rte3=cRRTE*ft4/cD0TE
rte4=cRRTE*ft5/cD0TE
vitep=(rte1+rte2)*ztes/2
vitmp=(rtm1+rtm2)*ztms/2
vitem=(rte3+rte4)*ztes/2
vitmm=(rtm3+rtm4)*ztms/2
vvtep=(rte1-rte2)/2
vvtmp=(rtm1-rtm2)/2
vvtem=(rte3-rte4)/2
vvtmm=(rtm3-rtm4)/2
iitep=-(rte1-rte2)/2
iitmp=-(rtm1-rtm2)/2
iitem=(rte3-rte4)/2
iitmm=(rtm3-rtm4)/2
ivtep=(-rte1-rte2)/ztef/2
ivtmp=(-rtm1-rtm2)/ztmf/2
ivtem=(rte3+rte4)/ztef/2
ivtmm=(rtm3+rtm4)/ztmf/2
! the source and observation points are not in the same layer
if (ns .ne. nf) then
if (ns .lt. nf) then
tev=cRTTEV
tei=cRTTEI
tmv=cRTTMV
tmi=cRTTMI
ivtem=(tei*(ft1-rte3+rte4))/ztef/2
ivtmm=(tmi*(ft1-rtm3+rtm4))/ztmf/2
ivtep=-tei*(rte1-rte2)/ztef/2
ivtmp=-tmi*(rtm1-rtm2)/ztmf/2
vitep=tev*(rte1+rte2)*ztes/2
vitmp=tmv*(rtm1+rtm2)*ztms/2
vitem=(tev*(ft1+rte3+rte4))*ztes/2
vitmm=(tmv*(ft1+rtm3+rtm4))*ztms/2
iitem=-tei*(ft1+rte3+rte4)*ztes/ztef/2
iitmm=-tmi*(ft1+rtm3+rtm4)*ztms/ztmf/2
iitep=-tei*(rte1+rte2)*ztes/ztef/2
iitmp=-tmi*(rtm1+rtm2)*ztms/ztmf/2
vvtem=(tev*(-ft1+rte3-rte4))/2
vvtmm=(tmv*(-ft1+rtm3-rtm4))/2
vvtep=tev*(rte1-rte2)/2
vvtmp=tmv*(rtm1-rtm2)/2
else
tev=CLTTEV
tei=CLTTEI
tmv=CLTTMV
tmi=CLTTMI
vvtem=(tev*(ft1+rte3-rte4))/2
vvtmm=(tmv*(ft1+rtm3-rtm4))/2
ivtem=(tei*(ft1+rte3-rte4))/ztef/2
ivtmm=(tmi*(ft1+rtm3-rtm4))/ztmf/2
ivtep=tei*(rte1-rte2)/ztef/2
ivtmp=tmi*(rtm1-rtm2)/ztmf/2
iitem=tei*(ft1+rte3+rte4)*ztes/ztef/2
iitmm=tmi*(ft1+rtm3+rtm4)*ztms/ztmf/2
iitep=tei*(rte1+rte2)*ztes/ztef/2
iitmp=tmi*(rtm1+rtm2)*ztms/ztmf/2
end if
end if
return
end
! LayerNo2
attributes(device) subroutine LayerNo2(pt,N,xloc,nlayer)
implicit none
integer N,index,nlayer
real pt,xloc(12)
if (pt .lt. xloc(1)) then
N=1
else if (pt .ge. xloc(nlayer-1)) then
N=nlayer
else
do 228 index=2, nlayer-1
if (pt .ge. xloc(index-1) .and. pt .lt. xloc(index)) then
N=index
end if
228 continue
end if
return
end
! 32 PO GAUSS QUADRATURE
attributes(device) SUBROUTINE GQ32A (FCT,Y)
COMPLEX FCT,Y
DIMENSION FCT(32)
Y=.35093050047350483E-2*(FCT(32)+FCT(1))
Y=Y+.8137197365452835E-2*(FCT(31)+FCT(2))
Y=Y+.12696032654631030E-1*(FCT(30)+FCT(3))
Y=Y+.17136931456510717E-1*(FCT(29)+FCT(4))
Y=Y+.21417949011113340E-1*(FCT(28)+FCT(5))
Y=Y+.25499029631188088E-1*(FCT(27)+FCT(6))
Y=Y+.29342046739267774E-1*(FCT(26)+FCT(7))
Y=Y+.32911111388180923E-1*(FCT(25)+FCT(8))
Y=Y+.36172897054424253E-1*(FCT(24)+FCT(9))
Y=Y+.39096947893535153E-1*(FCT(23)+FCT(10))
Y=Y+.41655962113473378E-1*(FCT(22)+FCT(11))
Y=Y+.43826046502201906E-1*(FCT(21)+FCT(12))
Y=Y+.45586939347881942E-1*(FCT(20)+FCT(13))
Y=Y+.46922199540402283E-1*(FCT(19)+FCT(14))
Y=Y+.47819360039637430E-1*(FCT(18)+FCT(15))
Y=Y+.48270044257363900E-1*(FCT(17)+FCT(16))
RETURN
END
! the direct term
attributes(device) subroutine fun0A(kz_s,xz,xzs,ci,fn0A)
implicit none
real xz,xzs
complex kz_s,fn0A,ci
fn0A=exp(-ci*kz_s*abs(xz-xzs))
return
end
! the direct term
attributes(device) subroutine fun1A(kz_s,xzcall,xzs,sign2,ci,fn1A)
implicit none
real xzcall,xzs
complex kz_s,fn1A,ci
integer sign2
fn1A=exp(-ci*kz_s*sign2*(xzcall-xzs))
return
end
! function the reflection from the left(lower) interface
attributes(device) subroutine fun2A(kz_s,xzcall,xzs,ns,sign2,xloc,ci,fn2A)
implicit none
integer ns,sign2
real xzcall,xzs,xloc(12)
complex kz_s,fn2A,ci
fn2A=exp(-ci*kz_s*abs((xzcall+xzs)-2.0*xloc(ns-1)))
return
end
! function the reflection from the right(upper) interface
attributes(device) subroutine fun3A(kz_s,xzcall,xzs,ns,sign2,xloc,ci,fn3A)
implicit none
integer ns,sign2
real xzcall, xzs,xloc(12)
complex kz_s,fn3A,ci
fn3A=exp(-ci*kz_s*(2.0*xloc(ns)-(xzcall+xzs)))
return
end
! function the reflection from the right interface--the third term
attributes(device) subroutine fun4A(kz_s,xzcall,xzs,ns,sign2,xloc,ci,fn4A)
implicit none
integer ns,sign2
complex kz_s,fn4A,cphi,ci
cphi=kz_s*(xloc(ns)-xloc(ns-1))
fn4A=exp(-2*ci*cphi+ci*kz_s*(xzcall-xzs))
return
end
attributes(device) subroutine fun5A(kz_s,xzcall,xzs,ns,sign2,xloc,ci,fn5A)
implicit none
integer ns,sign2
complex kz_s,fn5A, cphi,ci
fn5A=exp(-2*ci*cphi-ci*kz_s*(xzcall-xzs))
return
end
!c******************************************************************
!c calculate Green's function for a point (xx, xy, xz),
! The source point is located at (xxs, xys, xzs)
attributes(device) subroutine GreenOnePointEJ(xrho,xzp,xzs,ca,cb,cG,Nrct)
implicit none
integer i,n, Nf,qN,Nrct
real xerr
real xrho,xzp,xzs
complex ca(200),cb(200),cG(9),cr(9)
qN=200-2
Nf=9
do 207 i=1,Nf
cG(i)=0
207 continue
! print*,'Nrct=',Nrct
do 208 i=1,Nrct
call lineinteEJ(Nf,xrho,xzp,xzs,ca(i),cb(i),cr)
do 209 n=1,Nf
cG(n)=cG(n)+cr(n)
209 continue
208 continue
xerr=1.0
i=Nrct+1
DO WHILE (xerr .eq. 1.0 .and. i .le. qN)
400 call lineinteEJ(Nf,xrho,xzp,xzs,ca(i),cb(i),cr)
xerr=0.0
i=i+1
cG(1)=cG(1)+cr(1)
if (cabs(cr(1)) .gt. tolerance1*cabs(cG(1))) xerr=1.0
do 210 n=2,Nf
cG(n)=cG(n)+cr(n)
if (cabs(cr(n)) .gt. tolerance1*cabs(cG(n))) then
xerr=1.0
end if
210 continue
END DO
return
end
attributes(device) subroutine lineinteEJ(Nf,xtrho,xzp,xzs,caK,cbK,cr1)
implicit none
real XU(32)
integer Nf
real xzp,xzs,xtrho
complex caK,cbK,cr1(9)
integer m,j,kk,Nseg
real xerr,xerr1,xerr3,xerr5,xerr7,xerr9,xerr11,xinv2pi,wmu
complex cr0(9),cf(9,32), ctf(32)
complex wer4,wer0,zxcons,zzcons,xzcons
complex ckrho,ckrho2,ctr,clen,cnewa,wer1,wer2,wer3,ert1,ert2
complex*16 ctx,cbj(-2:2),ch(-2:2),cjp(-2:2),chp(-2:2)
complex iiitem,iiitep,iivtem,iivtep,ivitem,ivitep,ivvtem,ivvtep
complex iiitmm,iiitmp,iivtmm,iivtmp,ivitmm,ivitmp,ivvtmm,ivvtmp
wmu=1/(xomega*xmu0)
zxcons=1/(xomega*xepsilon0*cer(nfield))
xzcons=-1/(xomega*xepsilon0*cer(nsource))
XU(1)=0.136806908E-02
XU(2)=0.719424423E-02
XU(3)=0.176188722E-01
XU(4)=0.325469620E-01
XU(5)=0.518394221E-01
XU(6)=0.753161931E-01
XU(7)=0.102758102E+00
XU(8)=0.133908941E+00
XU(9)=0.168477867E+00
XU(10)=0.206142121E+00
XU(11)=0.246550046E+00
XU(12)=0.289324362E+00
XU(13)=0.334065699E+00
XU(14)=0.380356319E+00
XU(15)=0.427764019E+00
XU(16)=0.475846167E+00
XU(17)=0.524153833E+00
XU(18)=0.572235981E+00
XU(19)=0.619643681E+00
XU(20)=0.665934301E+00
XU(21)=0.710675638E+00
XU(22)=0.753449954E+00
XU(23)=0.793857879E+00
XU(24)=0.831522133E+00
XU(25)=0.866091059E+00
XU(26)=0.897241898E+00
XU(27)=0.924683807E+00
XU(28)=0.948160578E+00
XU(29)=0.967453038E+00
XU(30)=0.982381128E+00
XU(31)=0.992805756E+00
XU(32)=0.998631931E+00
xinv2pi=1.0/(2.0*xpi)
clen=cbK-caK
do 211 j=1,32
ckrho=clen*XU(j)+caK
ckrho2=ckrho**2
zzcons=ckrho2/(xomega**2*xepsilon0**2*cer(nfield)*cer(nsource))/ci
call Spectral(xtrho,ckrho,xzp,xzs,nsource,nfield, &
& iiitem,iiitep,iivtem,iivtep,ivitem,ivitep,ivvtem,ivvtep,&
& iiitmm,iiitmp,iivtmm,iivtmp,ivitmm,ivitmp,ivvtmm,ivvtmp)
ctx = ckrho*xtrho
call bslsdr(2,ctx,cbj,ch,cjp,chp,2)
if ( xtrho .eq. 0.0) then
wer0=(cbj(0)*ckrho-ckrho)*xinv2pi
wer2=cbj(1)*ckrho2*xinv2pi
wer3=cbj(0)*ckrho*xinv2pi
wer1=-ci*(cbj(0)*ckrho-ckrho/2)*xinv2pi
wer4=-ci*ckrho*xinv2pi/2
else
wer0=(cbj(0)*ckrho-2*cbj(1)/xtrho)*xinv2pi
wer1=-ci*(cbj(0)*ckrho-cbj(1)/xtrho)*xinv2pi
wer4=-ci*cbj(1)*xinv2pi/xtrho
end if
cf(1,j) = (ivitep+ivitem)*wer1*wmu
cf(2,j) = (ivitmp+ivitmm)*wer1*wmu
cf(3,j) = (ivvtmm+ivvtmp)*wer2*wmu*xzcons
cf(4,j) = (iiitmm+iiitmp)*wer2*wmu*zxcons
cf(5,j) = (iivtmm+iivtmp)*wer3*wmu*zzcons
cf(6,j) = (ivitmp+ivitmm)*wer4*wmu
cf(7,j) = (ivitep+ivitem)*wer4*wmu
cf(8,j) = -ci*(ivitep+ivitem)*wer0*wmu
cf(9,j) = -ci*(ivitmp+ivitmm)*wer0*wmu
211 continue
do 212 m=1,Nf
do j=1,32
ctf(j)=cf(m,j)
end do
call GQ32A(ctf,ctr)
cr0(m)=ctr*clen
212 continue
Nseg=1
99 Nseg=Nseg*2
clen=(cbK-caK)/float(Nseg)
do m=1,Nf
cr1(m)=0
end do
do kk=1,Nseg
cnewa=caK+float(kk-1)*clen
do j=1,32
ckrho=clen*XU(j)+cnewa
ckrho2=ckrho**2
ctx = ckrho*xtrho
else
end if
end do
do m=1,Nf
do j=1,32
ctf(j)=cf(m,j)
end do
call GQ32A(ctf,ctr)
cr1(m)=cr1(m)+ctr*clen
end do
end do
xerr1=0.0
xerr3=0.0
xerr5=0.0
xerr7=0.0
xerr9=0.0
if (cabs(cr1(1)-cr0(1)) .gt. tolerance2*cabs(cr1(1))) xerr1=1.0
if (cabs(cr1(3)-cr0(3)) .gt. tolerance2*cabs(cr1(3))) xerr3=1.0
if (cabs(cr1(5)-cr0(5)) .gt. tolerance2*cabs(cr1(5))) xerr5=1.0
if (cabs(cr1(7)-cr0(7)) .gt. tolerance2*cabs(cr1(7))) xerr7=1.0
if (cabs(cr1(9)-cr0(9)) .gt. tolerance2*cabs(cr1(9))) xerr9=1.0
xerr=max(xerr1,xerr3,xerr5,xerr7,xerr9)
DO WHILE (xerr.eq. 1.0 .and. Nseg .le. 513)
do m=1,Nf
cr0(m)=cr1(m)
end do
Nseg=Nseg*2
do m=1,Nf
cr1(m)=0
end do
do kk=1,Nseg
do j=1,32
ckrho2=ckrho**2
ctx = ckrho*xtrho
else
end if
end do
do m=1,Nf
do j=1,32
ctf(j)=cf(m,j)
end do
call GQ32A(ctf,ctr)
end do
end do
xerr1=0.0
xerr3=0.0
xerr5=0.0
xerr7=0.0
xerr9=0.0
END DO
return
end
attributes(device) subroutine R_left(ckrho2,xz,ns,nf,cR_leftTE,cR_leftTM,&
& cLTTEV,cLTTMV,cLTTEI,cLTTMI)
implicit none
integer n,ns,nf
real xz
complex ckrho2,cR_leftTE,cR_leftTM
complex cZTE,cZTM,ctant,cphi
complex ckz(1:nlayermax),cRTE(1:nlayermax-1),cRTM(1:nlayermax-1)
complex cpsi(1:nlayermax-1)
complex cLTTEV,cLTTMI,cLTTMV,cLTTEI
complex const1,const2
cLTTEV=1.0
cLTTMI=1.0
cLTTEI=1.0
cLTTMV=1.0
cR_leftTE=0.0
cR_leftTM=0.0
cRTE(ns)=0.0
cRTM(ns)=0.0
if (pec_first .eqv. .true.) then
if (ns .ne. 2) then
ckz(2)=csqrt(ck(2)**2-ckrho2)
call process_ckz(ckz(2))
cpsi(2)=exp(-ci*ckz(2)*(xloc(2)-xloc(1)))
cphi=cpsi(2)**2
ctant=(1-cphi)/(1+cphi)
cZTE=mur(2)*ctant/ckz(2)
cZTM=ckz(2)/cer(2)*ctant
cRTE(2)=-1
cRTM(2)=-1
do 250 n=3,ns
ckz(n)=csqrt(ck(n)**2-ckrho2)
call process_ckz(ckz(n))
call InputImpedance(ckz(n),n,cZTE,cZTM,&
& CRTE(n),cRTM(n),cpsi(n),mur,cer,nlayer,xloc,ci)
250 continue
cR_leftTE=cRTE(ns)
cR_leftTM=cRTM(ns)
else
CR_leftTE=-1
cR_leftTM=-1
end if
else
ckz(1)=csqrt(ck(1)**2-ckrho2)
call process_ckz(ckz(1))
cZTE=mur(1)/ckz(1)
cZTM=ckz(1)/(cer(1))
do 251 n=2,ns
251 continue
cR_leftTE=cRTE(ns)
cR_leftTM=cRTM(ns)
end if
const1=exp(-ci*ckz(nf)*(xloc(nf)-xz))
if (nf .eq. 1) then
cLTTEV=const1
cLTTMI=const1
cLTTEI=const1
cLTTMV=const1
else
const2=exp(-ci*2*ckz(nf)*(xz-xloc(nf-1)))
cLTTEV=const1*(1+cRTE(nf)*const2)/(1+cRTE(nf)*cpsi(nf)**2)
cLTTMV=const1*(1+cRTM(nf)*const2)/(1+cRTM(nf)*cpsi(nf)**2)
cLTTMI=const1*(1-cRTM(nf)*const2)/(1+cRTM(nf)*cpsi(nf)**2)
cLTTEI=const1*(1-cRTE(nf)*const2)/(1+cRTE(nf)*cpsi(nf)**2)
end if
do 252 n=nf+1,ns-1
cLTTEV=cLTTEV*(1+cRTE(n))*cpsi(n)/(1+cRTE(n)*cpsi(n)**2)
cLTTMV=cLTTMV*(1+cRTM(n))*cpsi(n)/(1+cRTM(n)*cpsi(n)**2)
cLTTMI=cLTTMI*(1+cRTM(n))*cpsi(n)/(1+cRTM(n)*cpsi(n)**2)
cLTTEI=cLTTEI*(1+cRTE(n))*cpsi(n)/(1+cRTE(n)*cpsi(n)**2)
252 continue
end if
return
end
! x field
! x source
attributes(device) subroutine R_right(ckrho2,xz,ns,nf,cR_rightTE,cR_rightTM,&
& cRTTEV,cRTTMV,cRTTEI,cRTTMI)
implicit none
integer n,ns,nf,nb
real xz
complex ckrho2,cR_rightTE,cR_rightTM
complex cRTTEV,cRTTMI,cRTTMV,cRTTEI
cRTTEV=1.0
cRTTMI=1.0
cRTTEI=1.0
cRTTMV=1.0
cR_rightTE=0.0
cR_rightTM=0.0
nb=nlayer-1
cRTE(ns)=0.0
cRTM(ns)=0.0
if (pec_last .eqv. .true.) then
if (ns .ne. nb) then
ckz(nb)=csqrt(ck(nb)**2-ckrho2)
call process_ckz(ckz(nb))
cpsi(nb)=exp(-ci*ckz(nb)*(xloc(nb)-xloc(nb-1)))
cphi=cpsi(nb)**2
cZTE=mur(nb)*ctant/ckz(nb)
cZTM=ckz(nb)/cer(nb)*ctant
cRTE(nb)=-1
cRTM(nb)=-1
do 256 n=nb-1,ns,-1
256 continue
cR_rightTE=cRTE(ns)
cR_rightTM=cRTM(ns)
else
CR_rightTE=-1
cR_rightTM=-1
end if
else
ckz(nlayer)=csqrt(ck(nlayer)**2-ckrho2)
call process_ckz(ckz(nlayer))
cZTE=mur(nlayer)/ckz(nlayer)
cZTM=ckz(nlayer)/(cer(nlayer))
do 257 n=nlayer-1,ns,-1
257 continue
cR_rightTE=cRTE(ns)
cR_rightTM=cRTM(ns)
end if
const1=exp(-ci*ckz(nf)*(xz-xloc(nf-1)))
if (nf .eq. nlayer) then
cRTTEV=const1
cRTTMI=const1
cRTTEI=const1
cRTTMV=const1
else
const2=exp(-ci*2*ckz(nf)*(xloc(nf)-xz))
cRTTEV=const1*(1+cRTE(nf)*const2)/(1+cRTE(nf)*cpsi(nf)**2)
cRTTMV=const1*(1+cRTM(nf)*const2)/(1+cRTM(nf)*cpsi(nf)**2)
cRTTMI=const1*(1-cRTM(nf)*const2)/(1+cRTM(nf)*cpsi(nf)**2)
cRTTEI=const1*(1-cRTE(nf)*const2)/(1+cRTE(nf)*cpsi(nf)**2)
end if
do 258 n=ns+1,nf-1
cRTTEV=cRTTEV*(1+cRTE(n))*cpsi(n)/(1+cRTE(n)*cpsi(n)**2)
cRTTMV=cRTTMV*(1+cRTM(n))*cpsi(n)/(1+cRTM(n)*cpsi(n)**2)
cRTTMI=cRTTMI*(1+cRTM(n))*cpsi(n)/(1+cRTM(n)*cpsi(n)**2)
cRTTEI=cRTTEI*(1+cRTE(n))*cpsi(n)/(1+cRTE(n)*cpsi(n)**2)
258 continue
end if
return
end
attributes(device) subroutine InputImpedance(ckz,n,cZTE,cZTM,cRTE,cRTM,cpsi,mur,cer,nlayer,xloc,ci)
implicit none
real mur(12),xloc(12)
complex cer(12),ci
integer n,nlayer
complex cphi,ckz,ctant,cZTE,cZTM,cZ0TE,cZ0TM
complex cRTE,cRTM, cpsi,reflr
cZ0TE=mur(n)/ckz
cZ0TM=ckz/cer(n)
call refl(cZTE,cZ0TE,reflr)
cRTE=reflr
call refl(cZTM,cZ0TM,reflr)
cRTM=reflr
cpsi=0
if (n .gt. 1 .and. n .lt. nlayer) then
cpsi=exp(-ci*ckz*(xloc(n)-xloc(n-1)))
cphi=cpsi**2
cZTE=cZ0TE*(cZTE+cZ0TE*ctant)/(cZ0TE+cZTE*ctant)
cZTM=cZ0TM*(cZTM+cZ0TM*ctant)/(cZ0TM+cZTM*ctant)
end if
return
end
! Calculate the reflection coefficient
attributes(device) subroutine refl(cZ, cZ0,reflr)
implicit none
complex reflr,cZ,cZ0
reflr=(cZ-cZ0)/(cZ+cZ0)
return
end
!===========================process_ckzA=============================
attributes(device) subroutine process_ckz(ckz)
implicit none
real xrkz, xikz
complex ckz,ci
ci=(0,1)
xrkz=real(ckz)
xikz=imag(ckz)
if (xrkz.lt.0) then
xrkz=-xrkz
end if
if (xikz.gt.0) then
xikz=-xikz
end if
ckz=xrkz+ci*xikz
return
end
attributes(device) subroutine bslsdr(n,x,cj,ch,cjp,chp,m)
parameter(nmax=36)
integer n,i,m
complex *16 cjd,chd,xd, jpd,hpd
complex *16 jd(-36:36),hd(-36:36)
complex *16 cj(-m:m), cjp(-m:m),ci
complex *16 ch(-m:m), chp(-m:m),x
double precision rn
ci=(0.0,1.0)
do i=-n,n
cj(i) = 0.0
cjp(i) = 0.0
ch(i) = 0.0
chp(i) = 0.0
end do
xd = x
call bes(xd,0,cjd,chd,0)
jd(0) = cjd
hd(0) = chd
ir=1
do i=1,n+1
call bes(xd,i,cjd,chd,0)
jd(i) = cjd
hd(i) = chd
jd(-i) = jd(i)
hd(-i) = hd(i)
if(ir.gt.0) jd(-i) = -jd(i)
if(ir.gt.0) hd(-i) = -hd(i)
ir = -ir
end do
do i=-n,n
rn=float(i)
jpd = rn*jd(i)-xd*jd(i+1)
hpd = rn*hd(i)-xd*hd(i+1)
cj(i) = jd(i)
ch(i) = hd(i)
cjp(i) = jpd
chp(i) = hpd
end do
return
end
! This is the code to calculate the Bessel Function of any order *
attributes(device) subroutine bes(x,i,bej,beh,iex)
!... x: the input variable.
!... i: order.
!... bej: the first order Bessel Function J0.
!... beh: the second order Bessel Function H0.
!... iex: the exponential index (exp(ix*iex). Suggested value: 0
real*8 pi,gr,gi,xi,ansr,ansi,anskr,anski !8 bytes means double precision
complex *16 ci,g,x,bej,beh !16 bytes means both the real and
!the imaginary parts are all in
!double precision
ci=(0.d0,1.d0)
pi=acos(-1.0)
xi=dimag(x)
g=x
if(xi.lt.0.d0)g=dconjg(x)
g=-ci*g
gr=dreal(g)
gi=dimag(g)
call bessel(gr,gi,i,ansr,ansi,anskr,anski)
bej=ci**i*dcmplx(ansr,ansi)
beh=2.d0*(-ci)**(i+1)*dcmplx(anskr,anski)/pi
if(xi.ge.0.d0)return
if(iex.eq.1)beh=beh*dexp(-2.d0*gr)
beh=2.d0*bej-beh
bej=dconjg(bej)
beh=dconjg(beh)
return
end
attributes(device) subroutine bessel (zr,zi,n,ansr,ansi,anskr,anski)
implicit double precision (a-h,o-z)
real pi
real gam
gam=.5772156649015328606d0
pi=3.14159265358979323846264338d0
sr=dsqrt(zr*zr+zi*zi)
if (sr-(14.+n/2.))300,310,310
300 continue
ffn=n
zdr=dabs(zr)
zdi=dabs(zi)
iq=1
if (zi.lt.0) then
iq=3
if (zr.ge.0.) iq=4
else
if (zr.le.0.) iq=2
end if
123 nm=n-1
cer1=zdr*.5d0
cei=zdi*.5d0
wsumr=0.
wsumi=0.
wwr=0.
wwi=0.
ucr=1.d0
uci=0.
if (n.ne.0) then
ucr=cer1
uci=cei
if (n.ne.1) then
br=ucr
bi=uci
do i=1,nm
temp1=ucr*br-uci*bi
uci=ucr*bi+uci*br
ucr=temp1
end do
end if
end if
210 on=1.d0
if (n.ne.0) on=(-1.d0)**n
ucir=ucr
ucii=uci
ucr=ucr*on
uci=uci*on
vcr=ucr*.5d0
vci=uci*.5d0
pn=0.
fn=1.d0
if (n.ne.0) then
do i=1,n
fi=i
pn=pn+1.d0/fi
fn=fn*fi
end do
end if
10 uur=1.d0/fn
uui=0.
vvr=pn/fn
vvi=0.
usumr=uur
usumi=0.
vsumr=vvr
vsumi=0.
temp1=cer1*cer1
temp2=cei*cei
cesr=temp1-temp2
cesi=2.d0*cer1*cei
if (n.ne.0) then
temp1=1.d0/(temp1+temp2)
wcr=cer1*temp1
wci=-cei*temp1
if (nm.ne.0) then
br=wcr
bi=wci
do i=1,nm
temp1=wcr*br-wci*bi
wci=wcr*bi+wci*br
wcr=temp1
end do
end if
221 wcr=wcr*.5d0
wci=wci*.5d0
fnm=fn/ffn
wsumr=fnm
wsumi=0.
if (nm.ne.0) then
wwr=fnm
wwi=0.
do k=1,nm
fk=k
ft=1.d0/(fk*(ffn-fk))
wwr=-wwr*ft
wwi=-wwi*ft
temp1=wwr*cesr-wwi*cesi
wwi=wwr*cesi+wwi*cesr
wwr=temp1
wsumr=wsumr+wwr
wsumi=wsumi+wwi
end do
end if
35 temp1=wsumr*wcr-wsumi*wci
wsumi=wsumr*wci+wsumi*wcr
wsumr=temp1
end if
100 pk=0.
do 20 k=1,33
fk=k
fnk=fk+ffn
d=fk*fnk
tr=cesr/d
ti=cesi/d
temp1=uur*tr-uui*ti
uui=uur*ti+uui*tr
uur=temp1
usumr=usumr+uur
usumi=usumi+uui
pk=pk+1.d0/fk
pn=pn+1.d0/fnk
cr=pn+pk
vvr=uur*cr
vvi=uui*cr
vsumr=vsumr+vvr
vsumi=vsumi+vvi
temp1=usumr
if (temp1.eq.0.) temp1=1.d0
temp2=usumi
if (temp2.eq.0.) temp2=1.d0
temp1=uur/temp1
temp2=uui/temp2
if (dabs(temp1).ge..1e-15) cycle
if (dabs(temp2).ge..1e-15) cycle
temp1=vsumr
temp2=vsumi
temp1=vvr/temp1
temp2=vvi/temp2
exit
20 continue
15 temp1=vsumr*vcr-vsumi*vci
vsumi=vsumr*vci+vsumi*vcr
vsumr=temp1
celr=.5d0*dlog(cer1*cer1+cei*cei)
celi=datan2(cei,cer1)
ar=gam+celr
ai=celi
temp1=ar*usumr-ai*usumi
ai=ar*usumi+ai*usumr
ar=ucr*temp1-uci*ai
ai=ucr*ai+uci*temp1
anskr=wsumr-ar+vsumr
anski=wsumi-ai+vsumi
if (sr.ge.5.+n/4.) call zk24 (zdr,zdi,n,anskr,anski)
ansr=usumr*ucir-usumi*ucii
ansi=usumr*ucii+usumi*ucir
if (iq.ne.1) then
if (iq.eq.4) then
60 ansi=-ansi
anski=-anski
else
70 cesr=1+2*(2*(n/2)-n)
if (iq.ne.3) then
usumr=ansr
usumi=-ansi
br=-pi*usumi
bi=pi*usumr
anski=-anski
anskr=cesr*anskr-br
anski=cesr*anski-bi
ansr=usumr*cesr
ansi=usumi*cesr
else
80 cr=-pi*ansi
ci1=pi*ansr
anskr=anskr*cesr+cr
anski=anski*cesr+ci1
ansr=ansr*cesr
ansi=ansi*cesr
end if
end if
end if
500 if (iexpck.eq.0) return
zrxp=dexp(zr)
anskr=anskr*zrxp
anski=anski*zrxp
ansr=ansr/zrxp
ansi=ansi/zrxp
return
310 call iln (zr,zi,n,ansr,ansi,anskr,anski)
return
end
attributes(device) subroutine iln (zr,zi,n,ansr,ansi,anskr,anski)
real pi
argr=2.d0*pi*zr
argi=2.d0*pi*zi
if (argr.ge.0.) then
pr=dsqrt((dsqrt(argr*argr+argi*argi)+argr)*.5d0)
pii=argi/(2.d0*pr)
else
if (dabs(argi/argr).lt.4.d-7) then
102 axi=dsqrt(dabs(argr))
if (argr.lt.0) then
103 pr=0.
pii=axi
if (argi.lt.0.) pii=-pii
else
104 pr=axi
pii=0.
end if
end if
end if
112 fn=n
fn2=4.d0*(fn**2)
ar=1.d0
if (iexpck.eq.0) ar=dexp(zr)
br=dcos(zi)
bi=dsin(zi)
ai=1.d0/(pr*pr+pii*pii)
cor=ar*(br*pr+bi*pii)*ai
coi=ar*(-br*pii+bi*pr)*ai
c2r=(br*pr-bi*pii)*ai/ar
c2i=(-br*pii-bi*pr)*ai/ar
ai=1+2*(2*(n/2)-n)
if (zi.lt.0.) ai=-ai
co2r=-ai*c2i
co2i=ai*c2r
if (iexpck.ne.0) then
tes0=dexp(-2.d0*zr)
co2r=co2r*tes0
co2i=co2i*tes0
end if
12 tes0=8.d0*dsqrt(zr*zr+zi*zi)
z8r=zr*8.d0
z8i=zi*8.d0
nk=37
psr=1.d0
psi=0.
pkr=1.d0
pki=0.
qsr=1.d0
qsi=0.
l=1
do 10 k=1,nk
l=-l
qk=l
kk=k-1
ts=(2*kk+1)**2
tt=k
tes1=tt*tes0
tes2=ts-fn2
if (tes2.ge.tes1) cycle
ar=pkr*tes2
ai=pki*tes2
br=tt*z8r
bi=tt*z8i
tem1=br*br+bi*bi
tem2=ai*br-ar*bi
pkr=(ar*br+ai*bi)/tem1
pki=tem2/tem1
psr=psr+pkr
psi=psi+pki
qsr=qsr+qk*pkr
qsi=qsi+qk*pki
10 continue
15 ar=cor*psr-coi*psi
ai=cor*psi+coi*psr
ansr=ar+co2r*qsr-co2i*qsi
ansi=ai+co2r*qsi+co2i*qsr
if (zi.eq.0.) ansi=0.
anskr=pi*(qsr*c2r-qsi*c2i)
anski=pi*(qsr*c2i+qsi*c2r)
return
end
attributes(device) subroutine zk24(zr,zi,n,zk1r,zk1i)
real x(12),c(12)
x( 1)= .361913603606156014d+02
x( 2)= .276611087798460900d+02
x( 3)= .213967559361661098d+02
x( 4)= .164321950876753130d+02
x( 5)= .123904479638094713d+02
x( 6)= .907543423096120287d+01
x( 7)= .636997538803063507d+01
x( 8)= .419841564487841315d+01
x( 9)= .250984809723212788d+01
x(10)= .126958994010396155d+01
x(11)= .454506681563780283d+00
x(12)= .503618891172939534d-01
c( 1)= .332873699297821780d-15
c( 2)= .131692404861563402d-11
c( 3)= .609250853997510780d-09
c( 4)= .803794234988285940d-07
c( 5)= .431649140980466720d-05
c( 6)= .113773832728087596d-03
c( 7)= .164738496537683500d-02
c( 8)= .140967116201453420d-01
c( 9)= .748909410064614920d-01
c(10)= .255479243569118320d+00
c(11)= .572359070692886040d+00
c(12)= .853862327737398500d+00
if (n.ge.7) then
call zk32(zr,zi,n,zk1r,zk1i)
return
end if
denr=1.d0
deni=0.
deni1=0.
sz=dsin(-zi)
cz=dcos(-zi)
if (n.ne.0) then
do i=1,n
temp=denr*zr-deni*zi
deni=denr*zi+deni*zr
denr=temp
end do
denr1=denr/(denr*denr+deni*deni)
if (zi.ne.0.) deni1=deni/(deni*deni+denr*denr)
end if
yr0=0.
yi0=0.
yr1=0.
yi1=0.
zrt=zr+zr
zit=zi+zi
do 10 i=1,12
tr=zrt+x(i)
temp=dsqrt(tr*tr+zit*zit)
ar=dsqrt((tr+temp)*.5d0)
if (ar.lt.0) ai=zit/(2.d0*ar)
if (ar.gt.0) ai=zit/(2.d0*ar)
if (ar.eq.o) ai=dsqrt(temp)
5 if (n.eq.0) then
cc=ar*ar+ai*ai
br0=ar/cc
bi0=-ai/cc
yr0=yr0+br0*c(i)
yi0=yi0+bi0*c(i)
else
6 br1=ar*x(i)
bi1=ai*x(i)
if (n.ne.1) then
br2=tr*x(i)
bi2=zit*x(i)
do k=2,n
temp=br1*br2-bi1*bi2
tkm=2*k-1
bi1=(br1*bi2+bi1*br2)/tkm
br1=temp/tkm
end do
end if
9 yr1=yr1+br1*c(i)
yi1=yi1+bi1*c(i)
end if
10 continue
et=dexp(-zr)
if (n.eq.0) then
zk1r=(yr0*cz-yi0*sz)*et
zk1i=(yi0*cz+yr0*sz)*et
else
12 zk2r=yr1*denr1+yi1*deni1
zk2i=yi1*denr1-yr1*deni1
zk1r=(zk2r*cz-zk2i*sz)*et
zk1i=(zk2r*sz+zk2i*cz)*et
end if
20 continue
return
end
attributes(device) subroutine zk32(zr,zi,n,zk1r,zk1i)
real x(16),c(16)
x( 1)= .507772238775370808d+02
x( 2)= .410816665254912019d+02
x( 3)= .337819704882261658d+02
x( 4)= .278314382113286757d+02
x( 5)= .228213006935252084d+02
x( 6)= .185377431786066933d+02
x( 7)= .148514313418012497d+02
x( 8)= .116770336739759564d+02
x( 9)= .895500133772339017d+01
x(10)= .664221517974144425d+01
x(11)= .470672670766758733d+01
x(12)= .312460105070214431d+01
x(13)= .187793150769607417d+01
x(14)= .953553155390865424d+00
x(15)= .342200156010947678d+00
x(16)= .379629145753134561d-01
c( 1)= .146213528547683240d-21
c( 2)= .184634730730365840d-17
c( 3)= .239468803418569740d-14
c( 4)= .843002042265289520d-12
c( 5)= .118665829267932772d-09
c( 6)= .819766432954179320d-08
c( 7)= .314833558509118800d-06
c( 8)= .730117025912475220d-05
c( 9)= .108331681236399652d-03
c(10)= .107253673105594410d-02
c(11)= .730978065330885620d-02
c(12)= .351068576631468600d-01
c(13)= .120916261911825228d+00
c(14)= .302539468153284960d+00
c(15)= .554916284605059800d+00
c(16)= .750476705185604780d+00
denr=1.d0
deni=0.
deni1=0.
sz=dsin(-zi)
cz=dcos(-zi)
if (n.ne.0) then
do i=1,n
denr=temp
end do
end if
4 yr0=0.
yi0=0.
yr1=0.
yi1=0.
zrt=zr+zr
zit=zi+zi
do 10 i=1,16
tr=zrt+x(i)
if (ar.eq.0) ai=dsqrt(temp)
5 if (n.eq.0) then
cc=ar*ar+ai*ai
br0=ar/cc
bi0=-ai/cc
yr0=yr0+br0*c(i)
yi0=yi0+bi0*c(i)
else
6 br1=ar
bi1=ai
p=x(i)
if (n.ne.1) then
br2=tr
bi2=zit
do 8 k=2,n
p=p*x(i)
tkm=2*k-1
br1=temp/tkm
8 continue
end if
9 yr1=yr1+br1*(c(i)*p)
yi1=yi1+bi1*(c(i)*p)
end if
10 continue
et=dexp(-zr)
if (n.eq.0) then
else
end if
20 continue
return
end
end module test
