Compiling
interface
subroutine a
end
end interface
end
pgfortran 18.10 gives the following warning:
There is no internal procedure to be seen.
Compiling
interface
subroutine a
end
end interface
end
Hi iabpab,
Correct. This compiler is issuing a generic error message that’s catching this issue but emitting a string tailored to a separate issue.
I can add an issue report. Though since other compilers compile this code without complaint, would you rather that I request that we accept this code without warnings or ask for the warning message be made more specific?
FYI, you can work around the warning by adding:
interface
subroutine a
end subroutine
end interface
end
-Mat
I certainly prefer the form with “end subroutine/function”, so I’d be happy with a warning message being more clear.
But I’d probably want it to be optional - using the MKL headers from Intel:
Although there’s an argument for not having a warning: the compiler seems content with
subroutine a
end
Sounds good. I added TPR#26894 to track this issue and will let our compiler folks determine the best course of action.
-Mat
