When importing a module with an “ONLY” clause, pgfortran does not enforce the only restriction.
In the code below, the second ALLOCATE statement should not be permitted. However compilation succeeds:
$ pgfortran useonly.f90
$ ./a.out
I = 3
I = -3
pgfortran 14.10-0 64-bit target on Apple OS/X -tp sandybridge
module m
implicit none
private
type, public :: base
integer :: i = 0
contains
procedure :: SetI => SetIBase
end type
type, public, extends(base) :: derived
contains
procedure :: SetI => SetIDerived
end type
contains
subroutine SetIBase(my,in)
class(base) :: my
integer, intent(in) :: in
my%i = in
end subroutine
subroutine SetIDerived(my,in)
class(derived) :: my
my%i = -in
end subroutine
end module
program test
use m, only: base
implicit none
class(base), pointer :: ptr
allocate(ptr)
call ptr%SetI(3)
print "('I = ',i0)", ptr%i
deallocate(ptr)
allocate(derived::ptr) ! <=== Not allowed here due to ONLY
call ptr%SetI(3)
deallocate(ptr)
end program
