While installing HDF4, the following was prompted:
pgf77 -c -o tvsetf.o tvsetf.f
PGFTN-S-0034-Syntax error at or near / (tvsetf.f: 855)
PGFTN-S-0034-Syntax error at or near / (tvsetf.f: 883)
PGFTN-W-0025-Illegal character (;) - ignored (tvsetf.f: 924)
PGFTN-S-0034-Syntax error at or near / (tvsetf.f: 967)
PGFTN-S-0034-Syntax error at or near / (tvsetf.f: 990)
0 inform, 1 warnings, 4 severes, 0 fatal for tvgroups
PGFTN/x86-64 Linux 15.7-0: compilation completed with severe errors
Makefile:771: recipe for target 'tvsetf.o' failed
make[2]: *** [tvsetf.o] Error 2
make[2]: Leaving directory '/opt/BRAMS-5.0/build/lib/hdf-4.2.11/hdf/test'
Makefile:393: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/opt/BRAMS-5.0/build/lib/hdf-4.2.11/hdf'
Makefile:481: recipe for target 'all-recursive' failed
make: *** [all-recursive] Error 1
Making install in hdf
make[1]: Entering directory '/opt/BRAMS-5.0/build/lib/hdf-4.2.11/hdf'
Making install in src
make[2]: Entering directory '/opt/BRAMS-5.0/build/lib/hdf-4.2.11/hdf/src'
make[3]: Entering directory '/opt/BRAMS-5.0/build/lib/hdf-4.2.11/hdf/src'
/usr/bin/mkdir -p '/usr/local/hdf/hdf4/lib'
/bin/sh ../../libtool --mode=install /usr/bin/install -c libdf.la '/usr/local/hdf/hdf4/lib'
libtool: install: /usr/bin/install -c .libs/libdf.lai /usr/local/hdf/hdf4/lib/libdf.la
libtool: install: /usr/bin/install -c .libs/libdf.a /usr/local/hdf/hdf4/lib/libdf.a
libtool: install: chmod 644 /usr/local/hdf/hdf4/lib/libdf.a
libtool: install: ranlib /usr/local/hdf/hdf4/lib/libdf.a
libtool: finish: PATH="/usr/lib64/qt-3.3/bin:/usr/lib64/ccache:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/waldyd/.local/bin:/home/waldyd/bin:/opt/pgi/linux86-64/15.7/bin:/usr/local/ncl_ncarg/bin/:/sbin" ldconfig -n /usr/local/hdf/hdf4/lib
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,-rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
/usr/bin/mkdir -p '/usr/local/hdf/hdf4/include'
/usr/bin/install -c -m 644 atom.h bitvect.h cdeflate.h cnbit.h cnone.h cskphuff.h crle.h cszip.h df.h dfan.h dfi.h dfgr.h dfrig.h dfsd.h dfstubs.h dfufp2i.h dynarray.h H4api_adpt.h h4config.h hbitio.h hchunks.h hcomp.h hcompi.h hconv.h hdf.h hdfi.h herr.h hfile.h hkit.h hlimits.h hproto.h hntdefs.h htags.h linklist.h mfan.h mfgr.h mstdio.h tbbt.h vattr.h vg.h '/usr/local/hdf/hdf4/include'
/usr/bin/install -c -m 644 hdatainfo.h hproto_fortran.h dffunc.f90 hdf.f90 dffunc.inc hdf.inc '/usr/local/hdf/hdf4/include'
make[3]: Leaving directory '/opt/BRAMS-5.0/build/lib/hdf-4.2.11/hdf/src'
make[2]: Leaving directory '/opt/BRAMS-5.0/build/lib/hdf-4.2.11/hdf/src'
Making install in fortran
make[2]: Entering directory '/opt/BRAMS-5.0/build/lib/hdf-4.2.11/hdf/fortran'
make[3]: Entering directory '/opt/BRAMS-5.0/build/lib/hdf-4.2.11/hdf/fortran'
make[4]: Entering directory '/opt/BRAMS-5.0/build/lib/hdf-4.2.11/hdf/fortran'
make[4]: Nothing to be done for 'install-exec-am'.
make[4]: Nothing to be done for 'install-data-am'.
make[4]: Leaving directory '/opt/BRAMS-5.0/build/lib/hdf-4.2.11/hdf/fortran'
make[3]: Leaving directory '/opt/BRAMS-5.0/build/lib/hdf-4.2.11/hdf/fortran'
make[2]: Leaving directory '/opt/BRAMS-5.0/build/lib/hdf-4.2.11/hdf/fortran'
Making install in test
make[2]: Entering directory '/opt/BRAMS-5.0/build/lib/hdf-4.2.11/hdf/test'
Makefile:393: recipe for target 'install-recursive' failed
make[1]: *** [install-recursive] Error 1
Makefile:481: recipe for target 'install-recursive' failed
make: *** [install-recursive] Error 1
Some of the offending lines are:
855 result = (/2, 3, 4, 5, 6, 7, 8, 9, 10, 11/)
883 result = (/7, 8, 9, 10, 11, 0, 0, 0, 0, 0/)
924 vdref_list(ii) = vdata_ref;
Any ideas about how to solve this issue?
