When compiling the following C++ statement with PGI 16.1
std::bitset<6> points[3];
I receive this error message:
PGCC-S-0000-Internal compiler error. ?? unexpected constant 10
This error was not present on PGI 15.10.
Additionally,
std::bitset<6> point;
compiles fine with PGI 16.1.
Is this a compiler bug, or am I missing something?
julianmi-
Thank you for the post.
This is a compiler bug. I have filed TPR 22304
The following code, compiled pgc++ -c++11 t.cpp
on a 4.9 system or above gets
PGCC-S-0000-Internal compiler error. ?? unexpected constant 10 (t.cpp)
t.cpp:
#include
main(){}
+1;
same error occurred for me in two places, it compiled perfectly fine in gcc-4.8; had to refactor my code to get around this problem and just not use arrays.
std::complex<double> complex_solutions[6];
typedef std::pair<float, int> Combination;
Combination results[3];
Thanks wbrennan92958. The fix for this is currently schedule to be available in the 16.3 release due out soon.
