It seams that the description of the environment variable PGI_ACC_NOTIFY in the User’s Guide is wrong.
It can be found in Table 20 on page 100.
As far as I tested the description in this slides on slide 3 seam to be right
Kind regards,
Dominik
Kind regards,
Dominik
Thanks. This will be fixed in the next release. It should say:
When set to an integer value, the value is used as a bit mask to print information about kernel launches (value 1), data transfers (value 2), wait operations or synchronizations with the device (value 4), region entry/exit (value 8), and data allocate/free (value 16).
