when I set PGI_ACC_TIME=1, my application ends with
[csc27:32581] *** Process received signal ***
[csc27:32581] Signal: Floating point exception (8)
[csc27:32581] Signal code: Invalid floating point operation (7)
[csc27:32581] Failing at address: 0x7ff51cbda5fd
[csc27:32581] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340)[0x7ff5ee666340]
[csc27:32581] [ 1] /opt/pgi/linux86-64/2016/cuda/7.0/lib64/libcupti.so(+0xaf5fd)[0x7ff51cbda5fd]
[csc27:32581] [ 2] /opt/pgi/linux86-64/2016/cuda/7.0/lib64/libcupti.so(+0xaefd1)[0x7ff51cbd9fd1]
[csc27:32581] [ 3] /opt/pgi/linux86-64/2016/cuda/7.0/lib64/libcupti.so(+0xaf2ef)[0x7ff51cbda2ef]
[csc27:32581] [ 4] /opt/pgi/linux86-64/2016/cuda/7.0/lib64/libcupti.so(+0x2cafc9)[0x7ff51cdf5fc9]
[csc27:32581] [ 5] /lib/x86_64-linux-gnu/libpthread.so.0(+0x8182)[0x7ff5ee65e182]
[csc27:32581] [ 6] /lib/x86_64-linux-gnu/libc.so.6(clone+0x6d)[0x7ff5edbf547d]
[csc27:32581] *** End of error message ***
mpirun noticed that process rank 0 with PID 32581 on node csc27 exited on signal 8 (Floating point exception).
With PGI_ACC_TIME=0, everything works as expected.
The code with the !$acc-directive:
!$acc kernels
DO itmp2 = 1, 8
DO itmp1 = 1, KLON
ZZ=SQRT (PUU(itmp1,itmp2))
ZXD=PGB(itmp1,itmp2,1)+ZZ*(PGB(itmp1,itmp2,2)+ZZ)
ZXN=PGA(itmp1,itmp2,1)+ZZ*(PGA(itmp1,itmp2,2))
PTT(itmp1,itmp2)=ZXN/ZXD
ENDDO
ENDDO
!$acc end kernels
Output of compiler:
mpif90 -c -I ../CBS -I /opt/pgi/linux86-64/2016/mpi/openmpi/include -Mcuda -Minfo=accel -module ../CODE -acc -c -byteswapio -O2 -Mvect=nosse -Ktrap=fp -Mr8 -g ../CODE/lwtt.f
lwtt:
103, Generating copyin(puu(:klon,:8),pgb(:klon,:,:),pga(:klon,:,:))
Generating copyout(ptt(:klon,:8))
104, Loop is parallelizable
105, Loop is parallelizable
Accelerator kernel generated
Generating Tesla code
104, !$acc loop gang, vector(4) ! blockidx%y threadidx%y
105, !$acc loop gang, vector(32) ! blockidx%x threadidx%x
