Hi All
Has anyone had any victories with building/installing OpenSSL with PGI ?
Thanks Much
Bill
Hi All
Thanks Much
Bill
Hi Bill,
I downloaded openssl-0.9.8g.tar.gz and do as follow for 64-bit:
2)Run: ./Configure linux-64-pgcc --prefix=/home/your_install_dir/openssl
3)Type: make
touch crypto/dsa/dsa_gen.c
Edit Makefile by replacing -O2 with -O0 in CFLAGS because one of the test will fail (dsatest). -O0 avoids the failure.
Type again: make to recompile dsa_gen.c
make test
If you don’t care for dsa, I guess you can ignore the error. I only tried generating rsa key and it works just fine. Hopefully it will work for other things too.
Hongyon
