Does PGI C compiler support packed C structure?
Example (that GNU and Intel support):
struct ti_header {
inttype size,code,dh,typesize,count;
char data;
} attribute((packed));
If not, is there something equivalent?
Thanks,
–rr
struct ti_header {
char data;
Thanks,
–rr
Hi rr,
Yes, PGI supports the packed attribute. This particular struct doesn’t need to be packed but if data was a single char, then you can see it when printing out the size of the struct.
Hope this helps,
Mat
% cat test1.c
#include <stdio.h>
#include <stdlib.h>
#include <inttypes.h>
typedef long inttype;
struct ti_header {
char data;
#ifdef USE_PACKED
} __attribute__((packed));
#else
#endif
void main () {
struct ti_header ti;
printf("%d\n", sizeof(ti));
exit(0);
% gcc test1.c ; a.out
48
% gcc test1.c -DUSE_PACKED ; a.out
41
% pgcc test1.c ; a.out
48
% pgcc test1.c -DUSE_PACKED ; a.out
41
