Hello, I’m trying to compile some software package named “xios” with fcm. And it compiles well with g++, but I could not make it work with pgi compiler. I got the following error.
“/usr/local/xios-2.5/inc/object_template.hpp”, line 85: error: “shared_ptr” is
ambiguous
shared_ptr getShared(void) ;
#######this it the working setup for g++ compiler#
%CCOMPILER mpicc
%FCOMPILER mpif90
%LINKER mpif90
%BASE_CFLAGS -ansi -w
%PROD_CFLAGS -O3 -DBOOST_DISABLE_ASSERTS
%DEV_CFLAGS -g -O2
%DEBUG_CFLAGS -g
%BASE_FFLAGS -D__NONE__
%PROD_FFLAGS -O3
%DEV_FFLAGS -g -O2
%DEBUG_FFLAGS -g
%BASE_INC -D__NONE__
%BASE_LD -lstdc++
%CPP cpp
%FPP cpp -P
%MAKE make
#########this is the PGI configuration I am trying to us##
%CCOMPILER mpicxx -noswitcherror
%FCOMPILER mpif90 -noswitcherror
%LINKER mpif90 -noswitcherror
%BASE_CFLAGS --c++11 -D__NONE__
%DEV_CFLAGS -g -traceback
%DEBUG_CFLAGS -DBZ_DEBUG -g -traceback -fno-inline
%PROD_FFLAGS -O3
%DEV_FFLAGS -g -O2 -traceback
%DEBUG_FFLAGS -g -traceback
%BASE_LD -c++libs
%CPP cpp
%FPP cpp -P
%MAKE make
