The following message when I checked the compiler:
cristiano@cristiano-VirtualBox:~$ pgf77 -v x.f
/opt/pgi/linux86/11.4/bin/pgftnc x.f -opt 1 -x 119 0xa10000 -x 119 0x100000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 127 17 -x 119 0x40000000 -x 19 0x400000 -x 28 0x40000 -x 120 0x10000000 -x 70 0x8000 -x 122 1 -x 59 4 -tp p7 -x 120 0x1000 -x 51 0x20 -x 124 0x1401 -astype 0 -stdinc /opt/pgi/linux86/11.4/include:/usr/local/include:/usr/lib/i386-linux-gnu/gcc/i686-linux-gnu/4.5.2/include:/usr/lib/i386-linux-gnu/gcc/i686-linux-gnu/4.5.2/include:/usr/include -def unix -def __unix -def unix -def linux -def __linux -def linux -def i386 -def __i386 -def i386 -def __NO_MATH_INLINES -def linux86 -def __THROW= -def extension= -def SSE -def MMX -def SSE2 -def SSE3 -def STDC_HOSTED -cmdline ‘+pgf77 x.f -v’ -x 124 1 -asm /tmp/pgf779BK3s5n3-au.s
pgi-f77-lin32: LICENSE MANAGER PROBLEM: Failed to checkout license
pgf77-Fatal-fcomp completed with exit code 1
Unlinking /tmp/pgf779BK3s5n3-au.s
which environment was initialized with:
export PGI=/opt/pgi
export PATH=$PGI/linux86/11.4/bin:$PATH
export LM_LICENSE_FILE=$PGI/license.dat
export LM_LICENSE_FILE=$PGI/license.dat:$LM_LICENSE_FILE
export MANPATH=$MANPATH:$PGI/linux86/11.4/man
after put license.dat in /opt/pgi with:
SERVER cristiano-VirtualBox 0800271b47cc
PACKAGE…
thanks,
Cristiano
