I tried using the __pgi_gangidx() function within a parallel loop, it works fine until I use it with “-ta=multicore” within a dynamically loaded library. In a regular binary it works fine, with “-ta=tesla” it also works fine in the DLL.
Is there a special linker flag one has to use? Does gangidx() under the hood use openmp functionality?
In general, the OpenACC targeting multicore does use much of the OpenMP runtime. I personally don’t use gangidx often since it’s a PGI extension, but it should correspond to omp_get_thread_num.
I haven’t tried using gangidx specifically in a DLL, but I have had other issues when not initializing the PGI runtime from DLLmain.
While it’s been a few years since I’ve done any work with DLLs, I use the following DLLmain, commenting or uncommenting out the different init calls depending on which target I’m using and if I’m linking with CUDA.
#include <windows.h>
#include <stdio.h>
#include <stdlib.h>
extern "C"
void _mp_preinit(void);
void __pgi_acc_preinit(void);
void __pgi_uacc_set_link_multicore(void);
void __pgi_uacc_set_link_cuda(void);
BOOL WINAPI DllMain(
HINSTANCE hinstDLL, // handle to DLL module
DWORD fdwReason, // reason for calling function
LPVOID lpReserved ) // reserved
// Perform actions based on the reason for calling.
switch( fdwReason )
case DLL_PROCESS_ATTACH:
long n;
// OpenACC targeting GPUs
// __pgi_acc_preinit();
// Iniit OpenMP runtime
_mp_preinit();
// Initialize OpenACC multicore runtime
__pgi_uacc_set_link_multicore();
// If linking with CUDA
// __pgi_uacc_set_link_cuda();
break;
case DLL_THREAD_ATTACH:
break;
case DLL_THREAD_DETACH:
break;
case DLL_PROCESS_DETACH:
break;
return TRUE; // Successful DLL_PROCESS_ATTACH.
