My operating system is CentOS4.4, when i run the pregrid.csh in regrid program using PGI release 7.05 in 32bit x86 platform, the following error occurred,
[root@gridlab100 pregrid]# ./pregrid.csh
Processing for SourceType = 3D
Starting ON84 processing for type 3D
cd /usr/src/redhat/BUILD/mm5V3-3.7.0/REGRID/pregrid/on84
ln -s /usr/src/redhat/BUILD/mm5V3-3.7.0/REGRID/pregrid/NCEP_ON84.9303 ON84FILEA
** pregrid version number: 0.28 **
HSTART, HEND = 1993-03-13_00:00:00 1993-03-14_00:00:00
Opening: ON84FILEA
Subroutine DATINT:
Interpolating 3-d files to fill in any missing data…
Looking for data at time 1993-03-13_00
Date not found: 1993-03-13_00:00:00
FORTRAN STOP
foreach: No match.
Does anyone know how to solve it? THANK YOU.
(Actually i already solve it by using PGI compiler release 6.08, but when i built this program in rpm package, it occurred another error during installation as below:
error: Failed dependencies:
libpgc.so is needed by mm5V3-regrid-3.7.0-1.i386
i try all possible to set library path such as add a line
export LD_LIBRARY_PATH=$PGI/lib
in /etc/bashrc
and type ldconfig in terminal command line, still face the same failed dependencies problem, so if anyone got good solution, pls HELP ME, THANK YOU)
