Hi, I am having a run time error I dont under stand and I dont know how to find out what is causing it.
error: in routine octree_search_particle there is a stack overflow: thread 7, max 1024KB, used 0KB, request 208B
the message make no sense as there is non used and the subroutine request is well within memory max.
the program is complied with the following options
fedora 20
pgf90 14.10-0 64-bit target on x86-64 Linux -tp sandybridge
F90FLAGS = -Mpreprocess -g -mp -r8 -DLinux -DnoReturnDamp -Kieee -Mchkptr -Mchkstk -Mbounds -traceback
and run with the following parameters
- OMP_NUM_THREADS=“8”, export OMP_NUM_THREADS
OMP_NESTED=“TRUE”, export OMP_NESTED
OMP_MAX_ACTIVE_LEVELS=“10”, export OMP_MAX_ACTIVE_LEVELS
OMP_STACKSIZE=“1G”, export OMP_STACKSIZE
ulimit -s unlimited
the memory usage was reports as mem kb = 9,915,484 on a machine with 128gb memory
the subroutine in question is an octree search routine which search thought a tree making a list of alll the partilces it find storing the list in massive. the section which uses this code is multithreaded and massive storage array is thread privated. I dont understand why the routine would break like this. I wanted to use allinea to debug my code but their memory debugger isnt up to the task and has a memory leak. I dont know how to find the source of the crash.
The memory debugging library (dmalloc - a replacement of regular malloc/free) is far less aggressive on reusing deallocated blocks. It can only do so if the size of new allocations match the size of previously freed blocks. Your executable is continuously requesting allocations with a very high variability of sizes, and therefore the amount of reuse is low and memory usage increases.
I have post the subroutine in question bellow.
RECURSIVE SUBROUTINE Octree_search_particle(BoxNumber, Particle, Search_distance, search_pad) !search by particle
use Main
IMPLICIT NONE
INTEGER, INTENT(in) :: BoxNumber, Particle
REAL*8 :: Search_distance
Logical :: WhichBoxes(8)
INTEGER :: ii, ParticleCheck, StoreNumber
REAL*8:: d_XYZ_octree(3), D_octree_2,D_octree, delta_octree, search_pad
!check depth and if bottom return
IF (Octree(boxNumber)%Depth == DepthMax) Then
StoreNumber = Octree(BoxNumber)%StoreNum
DO ii=Octree_Store_reference(1,StoreNumber) , Octree_Store_reference(3,StoreNumber)
ParticleCheck = Octree_store_current(ii)
IF(ParticleCheck < 1) Cycle !dont check your self or any particle bellow high or negative etc...
IF(ParticleCheck == Particle) Cycle !dont check your self or any particle bellow high or negative etc...
IF(unborn(ParticleCheck)) CYCLE
d_XYZ_octree(1:3) = XYZ(1:3,ParticleCheck) - XYZ(1:3,Particle)
D_octree_2 = DOT_PRODUCT(d_XYZ_octree,d_XYZ_octree)
D_octree = DSQRT(D_octree_2)!Pythagoras(dx,dy,dz)
delta_octree = D_octree - r(Particle) - r(ParticleCheck)
IF (delta_octree < Search_distance) THEN
Massive_store(massive_nb) = ParticleCheck
massive_nb = massive_nb + 1
IF (massive_nb > massive_lenght) CAll massive_Grow
END IF
END DO
Return
END IF
!logic search
!!!!6---8!!
!!5---7!!!!
!!!!!!!!!!! y split
!!!!2---4!!
!!1---3!!!!
!rules out boxes which cant be true.
WhichBoxes = .false.
!Split boxes in X
IF ((XYZ(1,Particle) - search_pad) > Octree(BoxNumber)%x(2)) Then
WhichBoxes(1:2) = .true.; WhichBoxes(5:6) = .true.
Else IF ((XYZ(1,Particle) + search_pad) < Octree(BoxNumber)%x(2)) Then
WhichBoxes(3:4) = .true.; WhichBoxes(7:8) = .true.
END IF
!split boxes in y
IF ((XYZ(2,Particle) - search_pad) > Octree(BoxNumber)%y(2)) Then
WhichBoxes(1:4) = .true.
Else IF ((XYZ(2,Particle) + search_pad) < Octree(BoxNumber)%y(2)) Then
WhichBoxes(5:8) = .true.
END IF
!split boxes in z
IF ((XYZ(3,Particle) - search_pad) > Octree(BoxNumber)%z(2)) Then
WhichBoxes(1) = .true.; WhichBoxes(3) = .true.; WhichBoxes(5) = .true.; WhichBoxes(7) = .true.
Else IF((XYZ(3,Particle) + search_pad) < Octree(boxNumber)%z(2)) Then
WhichBoxes(2) = .true.; WhichBoxes(4) = .true.; WhichBoxes(6) = .true.; WhichBoxes(8) = .true.
END IF
!debug = 0
DO ii = 1, 8
IF (WhichBoxes(ii)) CYCLE !not searched
IF (Octree(boxNumber)%ChildList(ii) < 1) cycle !CHILD DOES NOT EXSIT
CAll Octree_search_particle(Octree(boxNumber)%ChildList(ii), Particle, Search_distance,search_pad) !search for particle
END DO
END SUBROUTINE Octree_search_particle
