Hi, there.
I met a very tricky problem when I used PGI visual fortran to build static library.
Here is my code:
[/code]logical function setmem(list,mlist,rlist,
& num,name,length,precis)
implicit none
include ‘allotd.h’
include ‘allotn.h’
include ‘cdata.h’
include ‘iodata.h’
include ‘iofile.h’
include ‘psize.h’
include ‘errchk.h’
include ‘pointer.h’
include ‘comblk.h’
include ‘w_int.h’
include ‘p_point.h’
logical pcomp
integer list,num,length,precis,ip,ipa, n,i, iot, lensav
integer dicloc, mlist(2,list), irp(2,2)
character name*(),dname5, rlist(list)*5
save
data irp / 8,8,4,8 /, iot / 9 /
c Find variable
mmax = 0
dname = name
n = max(1,min(num,list))
c Check match of number with name of array
if(pcomp(dname,rlist(n),5)) then
c Set pointer for arrays stored in Blank Common
setmem = .true.
if(mlist(1,n).eq.0) then
if(length.le.0) then
write( ,) ’ WARNING Length allocation for:’,dname,
& ’ Length =’,length
write(iow,*) ’ WARNING Length allocation for:’,dname,
endif
ip = abs(precis)
ipa = irp(ip,ipr)
c Use Malloc to allocate space for lengthipa bytes
adr(n) = malloc(lengthipa)
c Set pointer for array use
if(ip.eq.1) then
np(n) = 1 + (adr(n) - loc(mr(1))) / ipa
else
np(n) = 1 + (adr(n) - loc(hr(1))) / ipa
endif
c Add new array into dictionary
ndict = ndict+1
mlist(1,n) = ndict
mlist(2,n) = length
if(ndict.le.200) then
dict(ndict) = dname
ipoint(ndict) = length
iprec(ndict) = ip
dlist(ndict) = n
if(num.le.llist) then
ddict(ndict) = num
else
ddict(ndict) = num-llist
endif
pdict(ndict) = num
else
write(iow,2001) dname
if(ior.lt.0) then
write(*,2001) dname
endif
endif
c Memory allocation available - Initialize to zero
if(adr(n).ne.0) then
if(ip.eq.1) then
call pzeroi(mr(np(n)),length)
else
call pzero (hr(np(n)),length)
endif
c Sufficient memory does not exist - Write ERROR message and STOP
else
write(iow,2000) name,length
if(ior.lt.0) then
write(*,2000) name,length
endif
if(eralloc) then
setmem = .false.
else
call plstop()
endif
endif
c Pointer already exists: Delete if length = 0;
elseif(length.eq.0) then
dicloc = mlist(1,n)
call free(adr(n))
np(n) = 0
mlist(1,n) = 0
mlist(2,n) = 0
do i = dicloc,ndict-1
dict(i) = dict(i+1)
ipoint(i) = ipoint(i+1)
iprec(i) = iprec(i+1)
dlist(i) = dlist(i+1)
ddict(i) = ddict(i+1)
pdict(i) = pdict(i+1)
mlist(1,dlist(i)) = mlist(1,dlist(i)) - 1
end do ! i
c Set last entry and reduce entries in dictionary
dict(ndict) = ’ ’
ipoint(ndict) = 0
dlist(ndict) = 0
ddict(ndict) = 0
pdict(ndict) = 0
iprec(ndict) = 0
c Reset dictionary lengths
ndict = ndict - 1
c Pointer already exists: resize in place
elseif(length.ne.mlist(2,n)) then
dicloc = mlist(1,n)
c Expand array if space available
ip = abs(precis)
ipa = irp(ip,ipr)
if(length.gt.mlist(2,n)) then
lensav = mlist(2,n)
else
lensav = length
endif
c Save current values
open (unit = iot, file = ‘scratch’, form = ‘unformatted’)
if(ip.eq.1) then
write(iot) (mr(point),point = np(n),np(n)+lensav-1)
else
write(iot) (hr(point),point = np(n),np(n)+lensav-1)
endif
call free(adr(n))
adr(n) = malloc(length*ipa)
rewind iot
if(ip.eq.1) then
read(iot) (mr(point),point = np(n),np(n)+lensav-1)
do i = mlist(2,n),length-1
mr(np(n)+i) = 0
end do ! i
else
read(iot) (hr(point),point = np(n),np(n)+lensav-1)
hr(np(n)+i) = 0.0d0
end do ! i
endif
endif
close(iot,status = ‘delete’)
c Set new pointers
mlist(2,n) = length
ipoint(dicloc) = length
c Cannot expand array, not enough space available
if(adr(n).eq.0) then
if(ior.lt.0) then
endif
if(eralloc) then
setmem = .false.
else
call plstop()
endif
endif
endif
else
c Error indicator
setmem = .false.
write( *,3000) num,dname
write(iow,3000) num,dname
else
write( *,3001) num-llist,dname
write(iow,3001) num-llist,dname
endif
endif
c Formats
2000 format(’ ERROR Insufficient storage to allocate ‘,a/,
& 11x,‘Required size =’,i12/,
& ’ Check data or choose other option.’)
2001 format(’ ERROR No more room in dictionary for ‘,a5)
3000 format(’ ERROR No allocation for array number’,i4,’ named: ‘,a)
3001 format(’ ERROR No allocation for user array number’,i4,
& ’ named: ',a)
end
When I want to implement my code, some error came out. Here is the error:
Error 1 Symbol, malloc, has not been explicitly declared
Actually, the intel visual fortan could build as usual. However, the error was always there.
Would please figure it out why such error occurred?
