I’m trying PGI to do FFT with cuFFT, but there’s an error message :
Here is my code:
#include <cufft.h>
// Declared extern "C" to disable C++ name mangling
extern "C" void for_CUFFT(float *d_data, int n, void *stream)
cufftHandle plan;
cufftPlan1d(&plan, n, CUFFT_C2C, 1);
cufftSetStream(plan, (cudaStream_t)stream);
cufftExecC2C(plan, (cufftComplex*)d_data, (cufftComplex*)d_data,CUFFT_FORWARD);
cufftDestroy(plan);
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include "openacc.h"
// Forward declaration of wrapper function that will call CUFFT
extern void for_CUFFT(float *d_data, int n, void *stream);
int main(int argc, char *argv[])
int n = 256;
float *data = (float* )malloc(2*n*sizeof(float));
int i;
// Initialize interleaved input data on host
for(i=0; i<2*n; i+=2) {
data[i] = i/2.0;
data[i+1] = 0.0;
// Copy data to device at start of region and back to host and end of region
#pragma acc data copy(data[0:2*n])
// Inside this region the device data pointer will be used
#pragma acc host_data use_device(data)
void *stream = acc_get_cuda_stream(acc_async_sync);
for_CUFFT(data, n, stream);
for(i=0; i<n; i+=2) {
printf("data[%d] = %f \n", i, data[i]);
return 0;
And my compiler command :
pgc++ -acc -ta=nvidia -Minfo -Mcudalib=cufft filename.cpp
I have stocked a week, do any one knows how to fix it?
