I am trying to setup the PGI compiler community ed. 19.10.
The compiler works normally, but on my first test with mpic++ (which I installed from the same pgi package) it produces unexpected warning message:
eric@hostname ~/Projects/MPI_tests mpic++ main.cpp
eric@hostname ~/Projects/MPI_tests mpirun -n 2 a.out
WARNING: Linux kernel CMA support was requested via the
btl_vader_single_copy_mechanism MCA variable, but CMA support is
not available due to restrictive ptrace settings.
The vader shared memory BTL will fall back on another single-copy
mechanism if one is available. This may result in lower performance.
Local host: hostname
Rank 0 OK!
Rank 1 OK!
[hostname:60252] 1 more process has sent help message help-btl-vader.txt / cma-permission-denied
[hostname:60252] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
which was produced by the code
#include <mpi.h>
#include <iostream>
int main(int argc, char* argv[])
MPI_Init(&argc, &argv);
int rank;
MPI_Comm_rank(MPI_COMM_WORLD, &rank);
if (rank == 0) {
int value = 17;
int result = MPI_Send(&value, 1, MPI_INT, 1, 0, MPI_COMM_WORLD);
if (result == MPI_SUCCESS)
std::cout << "Rank 0 OK!" << std::endl;
} else if (rank == 1) {
int value;
int result = MPI_Recv(&value, 1, MPI_INT, 0, 0, MPI_COMM_WORLD,
MPI_STATUS_IGNORE);
if (result == MPI_SUCCESS && value == 17)
std::cout << "Rank 1 OK!" << std::endl;
MPI_Finalize();
return 0;
This does not look normal. What shall I try to solve this issue?
