I can not compile a file where I manually include the lio_listio prototype, even though its the same as the one from the aio.h header:
$ pgcc -V
pgcc 18.10-1 64-bit target on x86-64 Linux -tp haswell
PGI Compilers and Tools
Copyright (c) 2018, NVIDIA CORPORATION. All rights reserved.
$ $ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/7/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 7.4.0-2ubuntu1~18.04~ppa1' --with-bugurl=file:///usr/share/doc/gcc-7/README.Bugs --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-7 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-libmpx --enable-plugin --enable-default-pie --with-system-zlib --with-target-system-zlib --enable-objc-gc=auto --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 7.4.0 (Ubuntu 7.4.0-2ubuntu1~18.04~ppa1)
$ cat >test-aio.c <<EOF
#include <aio.h>
EOF
$ pgcc -c test-aio.c
$ pgcc -E test-aio.c >test-aio.i
$ cat >>test-aio.c <<EOF
extern int lio_listio ( int __mode ,
struct aiocb \* const __list [ restrict ] ,
int __nent , struct sigevent \* __restrict __sig )
EOF
PGC-S-0137-Incompatible prototype declaration for function lio_listio (test-aio.c: 5)
PGC/x86-64 Linux 18.10-1: compilation completed with severe errors
What am I doing wrong here?
Bert
