I’m trying to profile some code I’ve been relooping into one giant outer loop using pgcollect. Following the benchADM example, I first compiled with (showing first file, driver.f90 and link stage use same options):
pgfortran -fast -Kieee -r4 -Mextend -Mpreprocess -Ktrap=fp -Minfo=ccff -Mpfi -c src/sorad.allreloop.f
I then ran the code which generated pgfi.out, and I then compiled with:
pgfortran -fast -Kieee -r4 -Mextend -Mpreprocess -Ktrap=fp -Minfo=ccff -Mpfo -c src/sorad.allreloop.f
and finally ran the code under pgcollect. After doing so, I go in and I see with the first main, big loop (that surrounds all the code):
4. Intensity = [symbolic], and not printable, try the -Mpfi -Mpfo options
So, I’m guessing I didn’t use the Mpfi/Mpfo options correctly. What is the correct sequence of running, the correct flags, &c., that I should use? Or, will profiling always “skip” the first, overarching loop like this? I do see compute intensity for the interior loops, I was just hoping to get a number for the big loop.
