When I execute pgprof, I am seeing the following error:
Exception in thread “main” java.lang.UnsatisfiedLinkError: /opt/pgi/linux86-64/7.2-5/jre/lib/i386/xawt/libmawt.so: Can’t load IA 32-bit .so on a IA 32-bit platform
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.load0(Unknown Source)
at java.lang.System.load(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at sun.security.action.LoadLibraryAction.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Toolkit.loadLibraries(Unknown Source)
at java.awt.Toolkit.(Unknown Source)
at splashLoader.main(splashLoader.java:42)
My environment vairiables are:
PGI=/opt/pgi
PATH=/opt/pgi/linux86-64/7.2-5/jre/bin:/usr/lib64/qt-3.3/bin:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin:/opt/pgi/linux86-64/7.2-5/bin:/home/west/bin
LM_LICENSE_FILE=/opt/pgi/license.dat
This is an HP DL585 with AMD Quad Core Opteron processors using Fedora 14 as the linux OS.
If anyone has any suggestions on how to resolve this problem, I would appreciate your advice.
Thanks,
Jim West
