pgprof text mode 7.1-3
I am tring to run pgprof in text mode ( (on my SUSE LINUX Enterprise Server 9 jre is at version 1.4)) with the following command but the shell is just… waiting
What am I missing?
pgprof -s -exe ./echam5 pgprof.out
I am not sure. What were the flags do you use to compile? Is this 32-bit or 64-bit program? How did you set PATH environment variable?
Can you run a simple program such as hello program to see if it works?
Note that a text version does not use Java.
Hongyon
thanks for your hint.
Indeed I was able to run pgprof on a simple program.
I rerun my original 64-bit one interactivly and now I have:
C-> pgprof -s -exe echam5.x pgprof.out
/opt/cluster/pgi/linux86-64/7.1-3/bin/pgprof: line 487: 14847 Segmentation fault $javaPATH $jMaxHeap “${jargs[@]}” -cp “$CP” $userRoot jpgprof “$path” “$@”
Is it possible for you to send us both executables(echam5 and echam5.x) and pgprof.out?
Please send to trs@pgroup.com and tell them to forward the information to me.
Thank you,
Hongyon
We found a problem and unfortunately there is no workaround for it. This will be fixed in 7.2 release which is expected to come out some time in May.
Thanks for you patience.
Hongyon
