pgprof: wrong(?) core counts in "system config"
Running pgprof (various versions <= 14.2) on 48-core node (4 x 12-core AMD) OpenSUSE 11.3, pgprof tells me
  • 9 cores per socket
    5 total cores
in the system configuration tab. Can someone explain what these values mean (the total is < per-socket count)? I was expecting 12 and 48 resp.
I see the same kind of unexpected numbers on other machines / Linux OSes.
thanks
Hi Tony,
I’ve been trying unsuccessfully to recreate this behavior here so passed it on to engineering to see if they can. Though, one thought I had is if you were running under a virtual environment or a scheduler (like torque) where you may not have full visibility of the system?
  • Mat
Hi Mat,
this is both on a compute node in a cluster allocated by SLURM (but no virtualization/cpusets etc) and on machines directly ssh’ed into. Screenshot example:
http://www.cs.uh.edu/~tonyc/pgprof.png
CentOS 5.10, 16 core (2 socket) machine, direct ssh login, trivial omp hello world example.
Update:
Also verified on a system where I am just a regular user and didn’t install anything (6 core * 2 socket = 12 core node reports: cores per socket = 4, total cores = 3).
Doesn’t appear to be anything to do with execstack message on libjpgprof64.so.
Should note this is for data collected by pgcollect. Using -Mprof gave me the right core/socket count. (Reporting on behalf of someone, so don’t have 100% of the info immediately to hand.)
