Dear NVidia Team
In the topic JetPack 5.0 DP - Ethernet Port "RGMII" not working with KSZ9031 we already mentioned that our PHY KSZ9031 does not work anymore with the new JetPack Version. With JetPack 4.6 and older, we did not see any problems.
Now we started testing with the release JetPack 5.0.2 and face again the same problem.
Do we need to change something in our configuration?
Here is our device tree:
out.dts (263.7 KB)
And here the dmesg output:
dmesg.txt (107.3 KB)
We specifically see these errors:
[ 8.251102] nvethernet 2490000.ethernet: Adding to iommu group 31
[ 8.251314] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[ 8.251319] nvethernet 2490000.ethernet: failed to read MDIO address
[ 8.251325] nvethernet 2490000.ethernet: setting to default DMA bit mask
[ 8.251328] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[ 8.251331] nvethernet 2490000.ethernet: Setting default PTP RX queue
[ 8.263234] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[ 8.263240] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[ 8.263244] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[ 8.271840] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:3c:8c:8e
[ 8.313819] nvethernet 2490000.ethernet: Macsec not supported
[ 8.326269] nvethernet 2490000.ethernet: eth5 (HW ver: 50) created with 1 DMA channels
[ 14.403333] using random self ethernet address
[ 14.411818] using random host ethernet address
[ 15.242098] using random self ethernet address
[ 15.243734] using random host ethernet address
[ 15.629056] nvethernet 2490000.ethernet: failed to connect PHY
[ 15.630774] net eth5: ether_open: Cannot attach to PHY (error: -19)
If you need further information, let us know.
Thank you.
Best regards
