"PHY to PHY" and "RGMII to RGMII"
What can high speed data communication Tech between Xaviers?
I have a project that requires the use of 2EA Xavier is in progress.
It is commonly understood to be implemented as a P2P Ethernet connection between Xaviers.
In this case, 2EA xavier mount on one carrier board.
I know that transformer is unnecessary. It consists of PHY to PHY.
Perhaps, Is it Possible?
  1. RGMII to RGMII
Hi, that’s not validated. You can consider PCIe for this, there is appnote in DLC: https://developer.nvidia.com/embedded/dlc/jetson-agx-xavier-series-pcie-endpoint-design-guidelines-application-note
