Hello, I have recently started using the PhysX 2.8.4 engine, and I have a problem regarding cooking a material. I have taken the example given in the documentation, but I am having trouble with the “MemoryWriteBuffer” and “MemoryReadBuffer”. The application simply does not recognise them, although I included everything that the examples contained. After searching a while on the internet, I found that these are contained in the Stream file, but I’‘ve looked there and they are not mentioned anywhere. Could you please help me? I really don’'t know how to solve this.
I managed to find the correct file to the problem above, but I get another one.
Hello, I have recently started using the PhysX 2.8.4 engine, and I have a problem regarding cooking a material. I have taken the example given in the documentation, but I get an error.
The code is as follows:
** Generate a uniform cloth patch, w and h are the width and height, d is the distance between vertices.
NxClothMeshDesc desc;
NxReal w = 0.8f;
NxReal h = 0.7f;
NxReal d = 0.15f;
int numX = (int)(w / d) + 1;
int numY = (int)(h / d) + 1;
desc.numVertices = (numX+1) * (numY+1);
desc.numTriangles = numX*numY*2;
desc.pointStrideBytes = sizeof(NxVec3);
desc.triangleStrideBytes = 3*sizeof(NxU32);
desc.points = (NxVec3*)malloc(sizeof(NxVec3)*desc.numVertices);
desc.triangles = (NxU32*)malloc(sizeof(NxU32)*desc.numTriangles*3);
desc.flags = 0;
int i,j;
NxVec3 *p = (NxVec3*)desc.points;
for (i = 0; i <= numY; i++) {
for (j = 0; j <= numX; j++) {
p->set(d*j, 0.0f, d*i);
p++;
NxU32 *id = (NxU32*)desc.triangles;
for (i = 0; i < numY; i++) {
for (j = 0; j < numX; j++) {
NxU32 i0 = i * (numX+1) + j;
NxU32 i1 = i0 + 1;
NxU32 i2 = i0 + (numX+1);
NxU32 i3 = i2 + 1;
if ((j+i)%2) {
*id++ = i0;
*id++ = i2;
*id++ = i1;
*id++ = i1;
*id++ = i2;
*id++ = i3;
else {
*id++ = i0;
*id++ = i2;
*id++ = i3;
*id++ = i0;
*id++ = i3;
*id++ = i1;
//cooking
NxClothMesh *mClothMesh;
static NxCookingInterface *gCooking = NxGetCookingLib(NX_PHYSICS_SDK_VERSION);
gCooking->NxInitCooking();
NxClothMeshDesc mdesc; //...
//Cook the mesh on the fly through a memory stream. //A file stream could also be used to pre-cook the mesh.
MemoryWriteBuffer wb;
if (!gCooking->NxCookClothMesh(mdesc, wb))
printf("Cooking failed!");
MemoryReadBuffer rb(wb.data);
try{
mClothMesh = gScene->getPhysicsSDK().createClothMesh(rb);}
catch (char *str)
printf(str);
//create cloth
NxClothDesc ndesc;
NxCloth *mCloth;
NxMeshData receiveBuffers; //Fill in receive buffers...
ndesc.clothMesh = mClothMesh;
ndesc.meshData = receiveBuffers;
mCloth = gScene->createCloth(ndesc);
And the error I get is:
Unhandled exception at 0x774e15de in IOPBTS.exe: 0xC0000005: Access violation reading location 0x00000000.
The exception appears at the following piece of code:
I also tried to replicate the example, I included everything there is, used same functions and same files, boxes get drawn but cloth does not, and it doesn’'t give any errors, as to indicate that it has not been created. Please help, because the documentation does not contain anything more specific and I have absolutely no other source for documentation or examples.
