Hi.
I´ve found maybe a possible bug ( or uncommented bad feature ) in PhysX.
I´m using filterShader, callbacks and trigger shapes, on
Windows 7 64 Bit, VS 2012, with debug library, in debug mode.
Its unimportant to show code I guess, because this is a common error.
My PxBoxController touch more than 1 trigger shape ( which will be deleted on touch. )
( Collecting items as example )
I know that its not possible (and a very bad idea) to delete an actor while the simulation is running, so
I bufferd each call to onTrigger / onContact in a list. Outside the simulation, I am updating
this list and the object which contains the actor is marked as deletable,
and on the next call of my object manager delete it and any reference on it
- which is after the whole update from PhysX. (Fixed timestep , mostly 1 - 3 calls for updating PhysX )
My problem is that sometimes in the simulation phase Physx thinks that is a good idea to set
the trigger/contact data ( mostly otherShape, but everything can it be ) to a non valid pointer like
0xfeeefeee. This happens a lot when PxPairFlag::eNOTIFY_TOUCH_LOST was set. But often - there
are only invalid pointer - or values which cant be read or be validaded.
( The whole PxTriggerPair* data is sometimes invalid ! )
{ Maybe you can understand what happend when you think of a stack with 3 boxes.
Delete the box in the middle - now the boxes received the PxPairFlag::eNOTIFY_TOUCH_LOST
with the (almost) deleted middle box. Should work in on the first update, on the next, it crashed.
Its possible to check against these bit pattern, but there are more pattern like
0xabababab or 0xcdcdcdcd - even those which arent have a special context - but mostly readable like
0xcdcd200f or similar.
Of course, its possible to catch these invalid pointer when you trying to read them with
a try catch block, ( with enabled \Eha in VS 2012 )
But … using a try catch block on invalid pointer … is a very very bad idea I think.
I dont know why PhysX should tell me: Hey, there was a deleted actor, here was the valid adress -
but I changed it to non NULL so you think its probably still valid.
When I call mScene->flush() its non deterministic when it crashs - and I dont get any error message from
PhysX - only from VS 2012 which says that I try to read an invalid adress.
And yes, as I said, its possible to catch that interrupt, but … it should´nt be there!
So, why does PhysX give me invalid pointer instead of NULL pointer?
