In PHysx 3.3.2, can the velocity of fluid in vessel distribute as parabolic velocity distribution, that is maximum in the center of the vessel, and minimum close to the wall? Because I found that in my experiment of fulid simualtion using Physx 3.3.2, the fluid velocity distribution is constant along the radius of the vessel.
Thank you
